Forum Index : Microcontroller and PC projects : Weird keys in MMbasic DOS
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6128 |
Hi all, When I run MMBASIC DOS version on windows 10, some key's on the keyboard behave weird. I have checked the manual, and geoff's page, but did not find a clue on how to fix it. Tried running MMbasic as XP, or even WIN98 (as close as windows 10 goes to DOS). The screen shows: I type " (a double quote) I get 80 (" Most characters are OK, but this also happens with ^ This is probably a very simple fix, or setting, but I am stuck. Please hint ..... Volhout PicomiteVGA PETSCII ROBOTS |
What keyboard settings do you have on your PC? It sounds like a key mapping issue. Jim VK7JH MMedit |
Hi TassyJim, Using a laptop, either with laptop keyboard, or with external USB keyboard. Both keyboards are listed in system manager as "standard PS2 keyboard" Language setting of the machine is English/USA. I do notice however that on this machine when typing the " character, it always acts strange. in WORD I get double double quotes "" in NOTEPAD I get nothing, but when I type a character next, the double quote appears. Looks like it is trying to compose a character or something. I'll dig into this a bit myself, since composing characters is something that happens in Holland, where I live, so it may be a hidden language in this PC causing this. I'll keep you posted... Regards, Harm PicomiteVGA PETSCII ROBOTS |
Solved !!! The keyboard was set to "QWERTY - US-International" I changed it to "QWERTY - US" now everything behaves as it should. Thanks for the hint... Volhout PicomiteVGA PETSCII ROBOTS |
