Local Time 18:35 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI TEXTBOX question....
Posted: 05:45am 21 Jun 2018
Hello all.
@ Geoff and/or matherp: Is there any way to change the layout of the textbox GUI control? Specifically, it is a PITA to have the DEL 'key' on the alternate page for this control, as users often touch the wrong letter and need to use the DEL/BACKSPACE key to erase their mistake, then type it again. The screen switching is annoying.
Thoughts?
Posted: 08:16am 21 Jun 2018
I will have a look at it but from what I remember there was no space on the first "page" for the DEL/BACKSPACE key. Is there some key on the first page that you believe would be better moved to the second?
Posted: 08:23am 21 Jun 2018
I know it is very tricky.....
Without adding another line of 'keys' to this GUI, how about replacing the uppercase arrow thing, with the DEL 'key'?
Perhaps this could be another option. I know you are loathe to keep adding more options, but perhaps.....
KeepIS
Posted: 05:40am 28 Jun 2018
Am I right in assuming that there is no way to use the Textbox as a multi line input text box, or to override centre justification of the entered text?
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
Posted: 07:45am 28 Jun 2018
Sorry, yes.
The GUI controls were designed for something simple like controlling a machine. Multi line input, moveable windows, etc is a whole new level.
Posted: 07:50am 28 Jun 2018
  Grogster said   I know it is very tricky.....
I think that this could be accomplished by squeezing the keys together slightly and adding another column of three keys on the right. With these extra keys we could have backspace plus full stop plus something else.
I will explore that option next.
KeepIS
Posted: 08:33am 28 Jun 2018
Thanks, I've decided to break the info I needed into fields and separate Textboxes, for what I want to do it's not worth coding something from scratch.
Posted: 08:48am 28 Jun 2018
@ Geoff: Sounds good to me.
