Local Time 11:37 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Video Chip
gadgetjack
Posted: 09:42pm 11 Jun 2018
For those looking to add video to there small micro projects , check out the data
sheet on this new ic. Part # VS23S010D-L . Has video memory for frame buffer and can run SPI or bus. It has my gears turning....
Posted: 10:17pm 11 Jun 2018
Link to PDF for this chip.....
I see this chip generates composite video. That might be a bit fuzzy for today's HD market. I am having a read of the PDF for this chip now though.
You might also be interested in the TellyMate composite video generating chip. Ideal for simple output, and I have used this device on a couple of projects and it works a treat. B/W only though.
gadgetjack
Posted: 12:41am 12 Jun 2018
I have built a few of those a few years back. Works good for simple b/w video.
Having a higher resolution and color with a frame buffer makes a bit more options
open. Do a search for stm32 basicengine for an example of this chip in use.
