Local Time 11:30 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Checking options at runtime
TrevorH
Posted: 01:16pm 08 Jun 2018
Hi everyone!
Is there anyway to check that an option has been set VERY early in a program before running the meat of the program and if not set giving an early exit without crashing the pic32?
Trevor
twofingers
Posted: 03:10pm 08 Jun 2018
Yes, I guess a CFunction would easily do that.
From CFunctions.h
//The Option structure
struct option_s {
char Autorun;
char Tab;
char Invert;
char Listcase;
char Height;
char Width;
int PIN;
int Baudrate;
int ColourCode;
// display related
char DISPLAY_TYPE;
char DISPLAY_ORIENTATION;
// touch related
char TOUCH_CS;
char TOUCH_IRQ;
char TOUCH_SWAPXY;
int TOUCH_XZERO;
int TOUCH_YZERO;
float TOUCH_XSCALE;
float TOUCH_YSCALE;
// for the SPI LCDs
char LCD_CD;
char LCD_CS;
char LCD_Reset;
// Note the next options are only applicable to the MM+
char SerialCon;
char SDCARD_CS;
char SD_CD;
char SD_WP;
char DISPLAY_BL;
char DISPLAY_CONSOLE;
char DefaultFont;
char KeyboardConfig;
char TOUCH_Click;
// To enable older CFunctions to run any new options *MUST* be added at the end of the list
But I can't do that at this time.
Michael
TrevorH
Posted: 03:56pm 08 Jun 2018
Thankyou for your reply, but I don't understand what you are telling me.
The problem I have is:-
my program uses the RTC on an E100 board, if I run the program without setting the RTC options, it crashes the PIC32. This forces me to do the multiple !!!!! thing to recover.
I would like to trap the fact that the RTC options are Not set BEFORE I run any more code.
Trevor.
twofingers
Posted: 04:30pm 08 Jun 2018
  TrevorH said
my program uses the RTC on an E100 board, ...
Upps, I guess there are no Cfunctions for the E100 (MMX?) possible.
Maybe Geoff or Peter have an idea? I am Sorry!
Posted: 04:33pm 08 Jun 2018
E100 is MM+ so no issue with cfunctions
PicFan
Posted: 04:47pm 08 Jun 2018
Maybe is this a solution ?
ON ERROR SKIP
RTC GETTIME
IF (MM.ERRNO <> 0) THEN
PRINT "NO RTC OPTION"
END
ENDIF
Edited by PicFan 2018-06-10
TrevorH
Posted: 05:36pm 08 Jun 2018
I think by running a RTC command is what is crashing the PIC when RTC options NOT set, but will check this out.
I was wondering if there is a way of checking which options are set or not Before running device dependant code.
@twofingers I am running a CFunction to enable a CPLD TFT screen already
Trevor.
twofingers
Posted: 05:50pm 08 Jun 2018
Trevor,
I fear there is no access (not yet) to the RTC options.
I don't have a MM+ so I can't test with it.
CircuitGizmos
Posted: 06:25pm 08 Jun 2018
I test for the RTC address having a device first before doing an RTC GETTIME.
I2C open 100, 1000 ' I2C enable at 100kHz with 1000ms time out
I2C read &H68, 0, 1, temp ' 3231 I2C address
IF MM.I2C = 0 Then
RTC GETTIME
EndIf
I2C close
TrevorH
Posted: 07:19pm 08 Jun 2018
@CircuitGizmos . Thanks for that I will give it a whirl.
Trevor
erbp
Posted: 01:16am 09 Jun 2018
I don't know if the following will help, but this is what I use to detect whether the RTC module is present or not on a MX170 which doesn't have an OPTION RTC … command.
SETPin Pin_Brake, Off 'release Pin 18
SetPin Pin_Reverse, Off 'release Pin 17
Pause 50
I2C Open 100, 200 'Open the I2C communication session
Pause 100
On Error Skip 1
RTC GetTime 'Set MM Date & Time from RTC module via I2C
If MM.ERRNO <> 0 then
'RTC not present (or failed to communicate) - Reset RTC_Flag
RTC_Flag = 0
etc. etc.
In this case I am even sharing the I2C pins with other functions and release them before opening the I2C connection and attempting to get the date/time from the RTC module.
I have NOT tried this approach on an E100 using the OPTION RTC … command.
Phil.
Posted: 04:01am 09 Jun 2018
  TrevorH said  my program uses the RTC on an E100 board, if I run the program without setting the RTC options, it crashes the PIC32. This forces me to do the multiple !!!!! thing to recover
on the face of it, this behaviour sounds like a bug in the mmbasic firmware. can peter or goeff comment?
rob :-)
Posted: 01:35am 11 Jun 2018
rob :-)
If you do not set the RTC option the RTC GETTIME command will try to use the standard I2C interface and if it cannot find the rtc it will give a message "RTC not responding".
It will not cause the PIC32 to crash. I don't know what is going on here but it is not the RTC command.
