Local Time 19:37 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dontronics Closure 6 weeks
donmck
Posted: 08:09am 13 May 2018
Dontronics Closure takes place in 6 weeks time on the 30th June 2018
Most unsold higher value stock will be returned to the manufacturers and other dealers.
All products on our pages are now heavily discounted.
We are open to reasonable offers on the remaining stock we have on hand.
A short list of remaining hardware items:
We do have a short list of hardware items that must be cleared in the next six weeks, and we are open to offers on bulk purchases. Many of these smaller items haven't been counted yet, but if you want the lot of any product (or everything), we can easily count them for you, so that we can negotiate a price. If these items are not cleared, they may well be thrown out.
See: https://www.shop-dontronics.com/Dontronics-Box-of-Goodies
for a full rundown on what is left in stock.
All of the minor items on this Stock Clearance list have had the prices reduced. These prices now range from 10 cents to $1
USB cables $1 each ONO in bulk. Suit small business or eBay seller.
35 x USB A Male to B Male Cables. (AM to BM)
69 x USB A Male to A Female Extension Cable. (AM to AF)
138 x USB A Male to B mini 5P Male Cable. (USB AM to Mini-5P)
16 x PoUSB12 $3 each ONO in bulk.
The PoUSB12 is a USB 2.0 (12Mbs maximum speed) to RS-232 bridge converter which is simple, cost-effective, very small and easy to use. It uses a USB-B type connector to connect to your PC and is based on the CP2102 Bridge from Silicon Labs. The PoUSB12 provides the user with multi baud rate serial data and access to USB control signals in a convenient 8 pin 2,54 mm (0.1") pitch package.
Many male and female gold plated connector pins in both straight and right angle types. 30 pin and dual 32 pins (64 pins)
These will suit microcontroller projects and I am open to offers on bulk orders on these.
And hundreds of USB to TTL FTDI cables $9 each, less for bulk.
Mick's Mites:
All MGB products are manufactured by Mick Gulovsen, and I have been doing just the sales machinery for him, as it is basically a hobby. Mick will handle this directly via email in the future.
Don McKenzie.
Dontronics Management.
https://www.dontronics.com
donmck
Posted: 09:29am 13 May 2018
I thought that Maximite users may have been interested in the FTDI USB to TTL 3V3 version with the 6 pin header, but an old customer just purchased the full 234 of them in one go.
I do have USB 3V3 cables with an AJ or audio jack connector on the end of them. These have a three wire cable which has RX, TX and ground, so it may suit some applications.
https://www.shop-dontronics.com/usb-to-ttl-cables/ftdi-ttl-232r-3v3aj-usb-to-serial-ttl-level-converter-cable.html
I also have some of The PoUSB12 is a USB 2.0 (12Mbs maximum speed) to RS-232 bridge converter which is simple, cost-effective, very small and easy to use. It uses a USB-B type connector to connect to your PC and is based on the CP2102 Bridge from Silicon Labs. The PoUSB 12 provides the user with multi baud rate serial data and access to USB control signals in a convenient 8 pin 2,54 mm (0.1") pitch package.
https://www.shop-dontronics.com/usb-converters/pousb12.html
Cheers Don...
Posted: 09:37am 13 May 2018
How many straight single pin-header strips do you have left in 30-pin flavour?
donmck
Posted: 08:08pm 13 May 2018
Hi Grogs,
If you can send me an email via support2018 AT dontronics.com so we can latch onto you directly, I'll get Penny to count the items and we can take it from there.
Cheers Don...
