Local Time 11:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CONSTRAIN(X,A,B)
redrok
Posted: 04:21pm 02 May 2018
Hi geoffg;
I would like to propose a new function:
CONSTRAIN(number, m, n )
This is very useful when used with sensor and AtoD converter.
I lifted this from the Arduino Language Reference:
constrain(x, a, b)
Description
Constrains a number to be within a range.
Parameters
x: the number to constrain, all data types
a: the lower end of the range, all data types
b: the upper end of the range, all data types
Returns
x: if x is between a and b
a: if x is less than a
b: if x is greater than b
This seems to be an easy function to build and could be quite useful.
What do you think?
redrok
Posted: 06:18pm 02 May 2018
I use MIN() and MAX() for this
so if I am after a value in a range (say between 100 & 200) I use the following:
x=Max(100,Min(200,reading))
this is the constrain function you are after. The reading will be limited to 100-200 and either be the reading or one of the boundaries:
> ? max(100,min(200,300))
200
> ? max(100,min(200,50))
100
> ? max(100,min(200,177))
177
Does this help?Edited by CaptainBoing 2018-05-04
redrok
Posted: 10:42pm 02 May 2018
Hi Captain;
  CaptainBoing said   I use MIN() and MAX() for this
200
100
177
Does this help?
Yes it does.
Combining max and min works very nicely.
Here's a small snipit I'm using in my Nixie Clock Experiments to Increment or Decrement a timing value on the fly:
If Q$="U" Then
Dimm=Max(0,Min(7,Dimm+1))
Print"Dimm";Str$(Dimm,2,1);"mS"
EndIf
If Q$="D" Then
Dimm=Max(0,Min(7,Dimm-1))
EndIf
Thanks!!!
redrok
Chopperp
Posted: 10:58pm 02 May 2018
Interesting. The only documentation I could find on Min() & Max() was in the blurb on Defined functions unless I've missed something
Works well for me as well.
Thanks Captain
ChopperP
Posted: 12:31am 03 May 2018
  Chopperp said  The only documentation I could find on Min() & Max() was in the blurb on Defined functions unless I've missed something
MAX() and MIN() were introduced in Ver 5.04.01. My guess is that the manual that you are using is before that.
Chopperp
Posted: 12:55am 03 May 2018
Ah, found it in my recently printed edition.
Thanks Geoff
EDIT. Found my 4 hole paper punch. Manual now in a folder. Much better than loose leafed. Edited by Chopperp 2018-05-04
ChopperP
Phil23
Posted: 10:04pm 03 May 2018
Needed a little brain exercise this morning...
Print "Constr(1,6,10)"
Print Constr(1,6,10)
Print
Print "Constr(8,6,10)"
Print Constr(8,6,10)
Print
Print "Constr(12,6,10)"
Print Constr(12,6,10)
Print
Function Constr(x%,a%,b%)
If (x%>=a% And x%<=b%) then
Constr=x%
Else If x%<a% then
Constr=a%
Else If x%>b% then
Constr=b%
End If
End Function
[Code]DOS MMBasic Ver 5.04.08
Copyright 2011-2017 Geoff Graham
Constr(1,6,10)
6
Constr(8,6,10)
8
Constr(12,6,10)
10
>[/code]
Phil.
rave
Posted: 01:17am 07 May 2018
My 2c:
I've been using the following Arduino-inspired functions and subs for my projects (as a MMBasic library), which includes a Constrain(x, lo, hi) function.
Granted, these are written for MMBasic 4.5. But should not be too difficult to upgrade these to MMBasic 5.x. A few are simply renamed MMBasic functions.
' BASIC functions and subroutines similar to Arduino math/bit/char functions
' Functions
' Sq(x) square of x
' Sqrt(x) square root of x
' Pow(x, y) raise x to the power y (same as x^y)
' Constrain(x, lo, hi) constrain x between lo and hi
' Map(x, lo, hi, newlo, newhi) map x between lo and hi to newlo and newhi
' Min(x, y) minimum of x and y
' Max(x, y) maximum of x and y
' Lsh(x, n) shift x left by n bits
' Rsh(x, n) shift x right by n bits
' Inv(x) invert bits (complement of x)
' Bit(n) value of n'th bit (same as 2^n)
' BitRead(x, n) n'th bit of x
' HighByte(x) high byte of word x
' LowByte(x) low byte of word x
' IsAlpha(a) true if a is alphabetic
' IsAlnum(a) true if a is alphanumeric
' IsCntrl(a) true if a is a control character
' IsDigit(a) true if a is a digit
' IsGraph(a) true if a is a graph character
' IsPrint(a) true if a is printable
' IsPunct(a) true if a is punctuation
' IsLower(a) true if a is lower case
' IsUpper(a) true if a is upper case
' IsSpace(a) true if a is white space
' Subroutines
' BitSet(x, n) set n'th bit of x
' BitClear(x, n) clear n'th bit of x
' BitToggle(x, n) toggle n'th bit of x
' BitWrite(x, n, b) set n'th bit of x to b
' RandomSeed(x) randomize with seed value x
' returns square of x
Function Sq(x)
Sq = x * x
End Function
' returns square root of x
Function Sqrt(x)
Sqrt = Sqr(x)
End Function
' returns x to the power y
Function Pow(x, y)
Pow = x ^ y
End Function
' returns value of x constrained between lo and hi
Function Constrain(x, lo, hi)
If x < lo Then
Constrain = lo
ElseIf x > hi Then
Constrain = hi
Else
Constrain = x
EndIf
End Function
' returns value of x between lo and hi mapped to range newlo and newhi
Function Map(x, lo, hi, newlo, newhi)
Map = (x - lo) * (newhi - newlo) / (hi - lo) + newlo
End Function
' returns minimum value of x and y
Function Min(x, y)
If x < y Then Min = x Else Min = y
End Function
' returns maximum value of x and y
Function Max(x, y)
If x > y Then Max = x Else Max = y
End Function
' returns x shifted left by n bits
Function Lsh(x, n)
Lsh = x * 2 ^ n
End Function
' returns x shifted right by n bits
Function Rsh(x, n)
Rsh = x \ 2 ^ n
End Function
' returns the complement of x
Function Inv(x)
Inv = -1 - x
End Function
' returns n'th bit value
Function Bit(n)
Bit = 2 ^ n
End Function
' returns n'th bit of x
Function BitRead(x, n)
BitRead = x And 2 ^ n
End Function
' set n'th bit of x
Sub BitSet(x, n)
x = x Or 2 ^ n
End Sub
' clear n'th bit of x
Sub BitClear(x, n)
x = x And -1 - (2 ^ n)
End Sub
' toggle n'th bit of x
Sub BitToggle(x, n)
x = x Xor 2 ^ n
End Sub
' set n'th bit of x to b
Sub BitWrite(x, n, b)
If b Then x = x Or 2 ^ n Else x = x And -1 - 2 ^ n
End Sub
' returns the high byte of a word
Function HighByte(x)
HighByte = x \ 256 And 255
End Function
' returns the low byte of a word
Function LowByte(x)
LowByte = x And 255
End Function
' returns random number between lo and exclusive hi
Function Random(lo, hi)
Random = lo + (hi - lo) * Rnd()
End Function
' set seed of random number generator
Sub RandomSeed(x)
Randomize x
End Sub
' returns true if a is alphabetic
Function IsAlpha(a)
IsAlpha = (a >= 65 And a <= 90) Or (a >= 97 And a <= 122)
End Function
' returns true if a is alphanumeric
Function IsAlnum(a)
IsAlnum = (a >= 48 And a <= 57) Or (a >= 64 And a <= 90) Or (a >= 97 And a <= 122)
End Function
' returns true if a is a control character
Function IsCntrl(a)
IsCntrl = (a >= 0 And a <= 31) Or a = 127
End Function
' returns true if a is a digit
Function IsDigit(a)
IsDigit = a >= 48 And a <= 57
End Function
' returns true if a is a graph character
Function IsGraph(a)
IsGraph = a >= 33 And a <= 126
End Function
' returns true if a is a printable character
Function IsPrint(a)
IsPrint = a >= 32 And a <= 126
End Function
' returns true if a is punctuation
Function IsPunct(a)
IsPunct = (a >= 33 And a <= 47) Or (a >= 58 And a <= 64) Or (a >= 91 And a <= 96) Or (a >= 123 And a <= 126)
End Function
' returns true if a is lower case
Function IsLower(a)
IsLower = a >= 97 And a <= 122
End Function
' returns true if a is upper case
Function IsUpper(a)
IsUpper = a >= 65 And a <= 90
End Function
' returns true if a is white space
Function IsSpace(a)
IsSpace = (a >= 9 And a <= 13) Or a == 32
End Function
- Rob
