Local Time 11:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picromite AUTORUN
Micro-80
Posted: 11:41am 02 May 2018
At startup, mmbasic does not display a message "file not found" if the file AUTORUN.BAS is missing. If the file AUTORUN.BAS is in the directory, then autorun does not happen. In OPTION i set "AUTORUN ON". MMBasic 5.4.17.
Micro-80
Posted: 07:59am 05 May 2018
All OK. The file name must be "AUTORUN.BAS". I used the name "autorun.bas"
Chopperp
Posted: 08:05am 05 May 2018
Good to see you found the problem.
ChopperP
Posted: 08:30am 05 May 2018
Sorry been away so hadn't had a chance to look at it but all filenames Pi-cromite are case sensitive (linux)Edited by matherp 2018-05-06
