Forum Index : Microcontroller and PC projects : Moon Phase
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
Has anyone weitten code to calculate the Moon Phase for the Micromite or Micromite+? I don't need anything complex like times or anything, just the phase on a given day |
| CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171 |
forum member cdeagle specialises in this maths-heavy, astronomical kind of stuff... have a look through his posts |
| Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667 |
There's some simple calc's here that might serve the purpose. Moon Phase Calcs. Phil. Edit;- Think I still have my Casio FX-201P sitting somewhere. Sheesh, I read 1976 when I clicked on it's link on that page.... |
| piclover Senior Member Joined: 14/06/2015 Location: FrancePosts: 134 |
Here's a extract of my meteo station program (which gives Moon phase and age, among other things). I hope I did not forget any chunk of code. REM Global variables declaration OPTION EXPLICIT REM tz is the time zone (e.g. 2.0 for UTC+2) REM moonphase is the percentage of the moon disk that is lit REM moonage is the number of days since last new moon DIM FLOAT tz,moonphase,moonage REM Constants CONST TO_DEG=57.2957795131 CONST TO_RAD=1.74532925199e-2 tz=2.0 ComputeMoonPhase() PRINT "Moon: "+STR$(moonphase*100.0,2,0)+"% "+STR$(moonage,2,1)+"d" REM Computes the number of Julian days elapsed since 2000-01-01 12:00 UTC for REM date d$ and time t$ (leave the latter empty to get the elapsed time in full REM days). Note: t$ is the local time (the time zone is subtracted from it). FUNCTION JD2000(d$,t$) LOCAL FLOAT jd LOCAL INTEGER day,month,year,hour,min,sec day=VAL(LEFT$(d$,2)):month=VAL(MID$(d$,4,2)):year=VAL(RIGHT$(d$,4))-2000 jd=365*year+(year+3)\4+275*month\9-((month+9)\12)*(1+((year MOD 4)+2)\3)+day-31 IF LEN(t$)=8 THEN hour=VAL(LEFT$(t$,2))-tz:min=VAL(MID$(t$,4,2)):sec=VAL(RIGHT$(t$,4)) jd=jd+hour/24.0+min/1440.0+sec/3600.0 ENDIF JD2000=jd END FUNCTION SUB ComputeMoonPhase() LOCAL FLOAT jd,N,M,Ec,Ls,ml,MM,MN,Ev,Ae,A3,MmP,mEc,A4,lP,V,lPP,NP,y,x LOCAL FLOAT Lm,BM,delta REM Constants for the Sun and the Moon at julian date 1980-01-00 CONST MAfactor=0.9856473321 CONST Elonge=278.83354 CONST Elongp=282.596403 CONST Eccent=0.016718 CONST Eccent2=1.016860112 CONST Mlfactor=13.1763966 CONST Mmlong=64.975464 CONST MMfactor=0.1114041 CONST Mmlongp=349.383063 CONST Mlnode=151.950429 CONST MNfactor=0.0529539 CONST Evfactor=1.2739 CONST Aefactor=0.1858 CONST A3factor=0.37 CONST mEcfactor=6.2886 CONST A4factor=0.214 CONST Vfactor=0.6583 CONST NPfactor=0.16 CONST CosMinc=0.995970321:REM COS(TO_RAD*5.145396) CONST SinMinc=8.9683442e-2:REM SIN(TO_RAD*5.145396) CONST Synmonth=29.53058868 REM Was 1e-6 in initial algorithm, but we only have simple precision floats CONST EPSILON=1e-5 REM 7306=days elapsed between 2000-01-01 and 1980-01-00=1979-12-31 jd=JD2000(DATE$,TIME$)+7306 N=MAfactor*jd:N=N-N\360*360.0 M=N+Elonge-Elongp:M=M-M\360*360.0:M=TO_RAD*M Ec=M DO delta=Ec-Eccent*SIN(Ec)-M Ec=Ec-delta/(1-Eccent*COS(Ec)) LOOP UNTIL ABS(delta)<=EPSILON Ec=Eccent2*TAN(Ec/2.0):Ec=2*TO_DEG*ATN(Ec) Ls=Ec+Elongp:Ls=Ls-Ls\360*360.0 ml=Mlfactor*jd+Mmlong:ml=ml-ml\360*360.0 MM=ml-MMfactor*jd-Mmlongp:MM=MM-MM\360*360.0 MN=Mlnode-MNfactor*jd Ev=Evfactor*SIN(TO_RAD*(2*(ml-Ls)-MM)) Ae=Aefactor*SIN(M):A3=A3factor*SIN(M) MmP=MM+Ev-Ae-A3 mEc=mEcfactor*SIN(TO_RAD*MmP):A4=A4factor*SIN(TO_RAD*2*MmP) lP=ml+Ev+mEc-Ae+A4 V=Vfactor*SIN(TO_RAD*2*(lP-Ls)):lPP=lP+V NP=MN-NPfactor*SIN(M) y=SIN(TO_RAD*(lPP-NP))*CosMinc:x=COS(TO_RAD*(lPP-NP)) Lm=TO_DEG*ATAN2(y,x)+NP BM=TO_DEG*ASIN(SIN(TO_RAD*(lPP-NP))*SinMinc) moonage=lPP-Ls moonage=moonage-moonage\360*360.0:IF moonage<0 THEN moonage=moonage+360.0 moonphase=0.5-COS(TO_RAD*moonage)/2.0 moonage=Synmonth*moonage/360.0 END SUB The original algorithm was written in PHP and is available here. |
Thanks for that link Phil. Based on the first algorithm (which the author says seems more accurate) I trans-coded (and simplified) the C to give the following function: Function MoonPhase(y As Integer,m As Integer,d As Integer) As Integer 'calculates the moon phase (0-7), accurate to 1 segment. '0 => new moon, 4 => full moon, 7= last part of third quarter ( before new) Local Float jd If m<3 Then y=y-1:m=m+12 m=m+1 jd=(((365.25*y)+(30.6*m)+d)-694039.09)/29.53 'total days divided by the moon cycle MoonPhase=Fix((jd-Int(jd))*8) Mod 7 End Function The phases seem to be broadly correct but only accurate to the nearest day; it doesn't work to hours. As an example, the full moon on December 22 here in the UK is at 17:48 - that is a good portion into the next day and the function returns a 5 (next segment after a full moon... however if you get the phase for the preceding day, it does return a 4 (full moon). This might also be down to the single precision of MMBasic (non MMX) as the original does specify double. So if you went out at 00:01 on 21/12 you might be irritated to see it not a full moon when this algorithm says it is, but at 23:59 the same day it would be hard to tell (besides the fact the moon would have gone - but let's ignore that )I don't think the algorithm is accurate enough for astronomical stuff but within a day makes it good for anything that just needs an indication or to know if it's worth going hunting. Good find |
I've done a lot of research trying to find an accurate but simple enough routine I've found a few examples but they are all too complex for me to decipher From what I've found the enclosed C code 2018-05-03_182843_LunarPhase.zip seems to be very accurate it's part of this program which calculates planatery hours I can't convert C to MM Basic accurately though Another good accurate one is this page but it's too complex for me to try and find the right part of it to use. This one also is reasonably accurate but it's in Python and I can't convert from that Ideally I'd like the Lunar day in numbers but quarters/half/full would do |
you have that above but the small inaccuracies are down (I am convinced) to the single precision maths of MMBasic. Unless you are using an MMX (or CMM?) here is an example : > a=0.5 > ? a 0.5 > > a=694039.09 > ? a 694039 see how the variable can't hold the detail AND the significant digits? this will definitely affect any scientific grade calculations... it is a microcontroller after all, need to keep expectation in perspective. There are possibly ways around this, but then you aren't going top get a precise function is seven lines of code (how simple do you want?) |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11902 |
MM+ is also now double precision in Geoff's latest release. The attached seems to work well. The phases aren't strictly correct as Full, Third quarter, new, and first quarter are strictly only one day - see this reference Note that you can include the hour in the call to moonphase and this can be a float so you can get the precise times of the various phases. The attached uses hour = 0, i.e.the start of the day specified. option explicit option default none dim integer k, a% dim phase$(7)=("New", "Waxing Crescent","First Quarter","Waxing Gibbous", "Full", "Waning Gibbous", "Third Quarter", "Waning Crescent") for k=1 to 31:? "2018 May ",k,str$(moon_phase(2018,5,k,0,a%),3,2)+"% ",phase$(a%):next k end function Julian(year as integer,month as integer,day as float) as float ' Returns the number of julian days for the specified day. local integer a,b=0,c,e if month < 3) then year=year-1 month =month+12 endif if (year > 1582 OR (year = 1582 and month>10) or (year = 1582 and month=10 and day > 15)) then a=year/100 b=2-a+a/4 endif c = 365.25*year e = 30.6001*(month+1) Julian= b+c+e+day+1720992.5 end function function sun_position(j as float) as float local float n,x,e,l,dl,v local float SMALL_FLOAT local integer i SMALL_FLOAT=2.718281828^(-12) n=360/365.2422*j i=n\360 n=n-i*360.0 x=n-3.762863 if x<0 then x = x+ 360 x=rad(x) e = x do dl = e - 0.016718 * sin(e) - x e = e - dl/ (1 - 0.016718 * cos(e)) loop while abs(dl)>=SMALL_FLOAT v=360/PI*atn(1.01686011182*tan(e/2)) l=v+282.596403 i=l\360 l=l-i*360.0 sun_position= l end function function moon_position(j as float, ls as float) as float local float ms,l,mm,n,ev,sms,ae,ec local integer i ms = 0.985647332099 * j - 3.762863 if ms < 0 then ms =ms + 360.0 l = 13.176396 * j + 64.975464 i = l \ 360 l = l - i * 360.0 if l < 0 then l = l + 360.0 mm = l - 0.1114041 * j - 349.383063 i = mm \ 360 mm = mm - i * 360.0 n = 151.950429 - 0.0529539 * j i = n \ 360 n = n- i * 360.0 ev = 1.2739 * sin(RAD((2*(l-ls)-mm))) sms = sin(RAD(ms)) ae = 0.1858*sms mm =mm+ ev-ae- 0.37*sms ec = 6.2886*sin(RAD(mm)) l =l + ev + ec -ae + 0.214 * sin(RAD(2*mm)) l= 0.6583*sin(RAD(2*(l-ls)))+l moon_position= l end function function moon_phase(year as integer,month as integer,day as integer, hour as float, ip as integer) as float ' Calculates more accurately than Moon_phase , the phase of the moon at ' the given epoch. ' returns the moon phase as a real number (0-1) ' local float j= Julian(year,month,day+hour/24.0)-2444238.5 local float ls = sun_position(j) local float lm = moon_position(j, ls) local float t = lm - ls if t < 0 then t = t + 360 ip = INT((t + 22.5)/45) AND 7 moon_phase = ((1.0 - cos(RAD(lm - ls)))/2)*100 end function |
Wow That's impressive |
I had to change line 80 to [quote]Lm=TO_DEG*(ATN(y)/ ATN(x))+NP[/quote] The results of both for today Piclover's Moon: 83% 18.8d (number of days since last new moon) Matherp's 2018 May 4 85.10% Waning Gibbous |
Anyone able to tell me why I cannot get this to work? It always prints the last item (Waning Crescent) and never the correct one I've tried every combination I can think of including VAL(STR(moonage)) changing the numbers to strings and using STR(moonage) and every combination I can think of with IF and ELSE IF I know I could use Peter's code but this one is very accurate [quote]'Global variables declaration cls OPTION EXPLICIT ' tz is the time zone (e.g. 2.0 for UTC+2) ' moonphase is the percentage of the moon disk that is lit ' moonage is the number of days since last new moon DIM FLOAT tz,moonphase,moonage ' Constants CONST TO_DEG=57.2957795131 CONST TO_RAD=1.74532925199e-2 tz=0.0 ComputeMoonPhase() PRINT "Moon: "+STR$(moonphase*100.0,2,0)+"% "+STR$(moonage,2,1)+"d" MoonImage Sub MoonImage if moonage < 1.5 then Text 280,310, "New Moon" , LB,4, 1, RGB(white) endif if moonage > 1.5 < 2.75 then Text 280,310, "Waxing Crescent" , LB,4, 1, RGB(white) endif if moonage > 2.75 < 4 then Text 280,310, "Waxing Crescent" , LB,4, 1, RGB(white) endif if moonage > 4 < 6.4 then Text 280,310, "Waxing Crescent" , LB,4, 1, RGB(white) print val(STR$(moonage,2,1)) endif if moonage > 6.4 < 8 then Text 280,310, "First Quarter" , LB,4, 1, RGB(white) endif if moonage > 8 < 10 then Text 280,310, "Waxing Gibbous", LB,4, 1, RGB(white) endif if moonage > 10 < 12 then Text 280,310, "Waxing Gibbous" , LB,4, 1, RGB(white) endif if moonage > 12 < 14 then Text 280,310, "Waxing Gibbous" , LB,4, 1, RGB(white) endif if moonage > 14 < 15.25 then Text 280,310, "Full Moon" , LB,4, 1, RGB(white) endif if moonage > 15 < 18 then Text 280,310, "Waning Gibbous" , LB,4, 1, RGB(white) endif if moonage > 18 and moonage < 20 then Text 280,310, "Waning Gibbous" , LB,4, 1, RGB(white) print moonage " test" endif if moonage > 20 < 22.3 then Text 280,310, "Waning Gibbous" , LB,4, 1, RGB(white) endif if moonage > 22.3 < 24 then Text 280,310, "Last Quarter" , LB,4, 1, RGB(white) endif if moonage > 24 < 26 then Text 280,310, "Waning Crescent" , LB,4, 1, RGB(white) endif if moonage > 26 < 28. then Text 280,310, "Waning Crescent" , LB,4, 1, RGB(white) endif if moonage > 28 then Text 280,310, "Waning Crescent" , LB,4, 1, RGB(white) ENDIF End sub ' Computes the number of Julian days elapsed since 2000-01-01 12:00 UTC for ' date d$ and time t$ (leave the latter empty to get the elapsed time in full ' days). Note: t$ is the local time (the time zone is subtracted from it). FUNCTION JD2000(d$,t$) LOCAL FLOAT jd LOCAL INTEGER day,month,year,hour,min,sec day=VAL(LEFT$(d$,2)):month=VAL(MID$(d$,4,2)):year=VAL(RIGHT$(d$,4))-2000 jd=365*year+(year+3)\4+275*month\9-((month+9)\12)*(1+((year MOD 4)+2)\3)+day-31 IF LEN(t$)=8 THEN hour=VAL(LEFT$(t$,2))-tz:min=VAL(MID$(t$,4,2)):sec=VAL(RIGHT$(t$,4)) jd=jd+hour/24.0+min/1440.0+sec/3600.0 ENDIF JD2000=jd END FUNCTION SUB ComputeMoonPhase() LOCAL FLOAT jd,N,M,Ec,Ls,ml,MM,MN,Ev,Ae,A3,MmP,mEc,A4,lP,V,lPP,NP,y,x LOCAL FLOAT Lm,BM,delta ' Constants for the Sun and the Moon at julian date 1980-01-00 CONST MAfactor=0.9856473321 CONST Elonge=278.83354 CONST Elongp=282.596403 CONST Eccent=0.016718 CONST Eccent2=1.016860112 CONST Mlfactor=13.1763966 CONST Mmlong=64.975464 CONST MMfactor=0.1114041 CONST Mmlongp=349.383063 CONST Mlnode=151.950429 CONST MNfactor=0.0529539 CONST Evfactor=1.2739 CONST Aefactor=0.1858 CONST A3factor=0.37 CONST mEcfactor=6.2886 CONST A4factor=0.214 CONST Vfactor=0.6583 CONST NPfactor=0.16 CONST CosMinc=0.995970321:' COS(TO_RAD*5.145396) CONST SinMinc=8.9683442e-2:' SIN(TO_RAD*5.145396) CONST Synmonth=29.53058868 ' Was 1e-6 in initial algorithm, but we only have simple precision floats CONST EPSILON=1e-5 ' 7306=days elapsed between 2000-01-01 and 1980-01-00=1979-12-31 jd=JD2000(DATE$,TIME$)+7306 N=MAfactor*jd:N=N-N\360*360.0 M=N+Elonge-Elongp:M=M-M\360*360.0:M=TO_RAD*M Ec=M DO delta=Ec-Eccent*SIN(Ec)-M Ec=Ec-delta/(1-Eccent*COS(Ec)) LOOP UNTIL ABS(delta)<=EPSILON Ec=Eccent2*TAN(Ec/2.0):Ec=2*TO_DEG*ATN(Ec) Ls=Ec+Elongp:Ls=Ls-Ls\360*360.0 ml=Mlfactor*jd+Mmlong:ml=ml-ml\360*360.0 MM=ml-MMfactor*jd-Mmlongp:MM=MM-MM\360*360.0 MN=Mlnode-MNfactor*jd Ev=Evfactor*SIN(TO_RAD*(2*(ml-Ls)-MM)) Ae=Aefactor*SIN(M):A3=A3factor*SIN(M) MmP=MM+Ev-Ae-A3 mEc=mEcfactor*SIN(TO_RAD*MmP):A4=A4factor*SIN(TO_RAD*2*MmP) lP=ml+Ev+mEc-Ae+A4 V=Vfactor*SIN(TO_RAD*2*(lP-Ls)):lPP=lP+V NP=MN-NPfactor*SIN(M) y=SIN(TO_RAD*(lPP-NP))*CosMinc:x=COS(TO_RAD*(lPP-NP)) Lm=TO_DEG*(ATN(y)/ ATN(x))+NP BM=TO_DEG*ASIN(SIN(TO_RAD*(lPP-NP))*SinMinc) moonage=lPP-Ls moonage=moonage-moonage\360*360.0:IF moonage<0 THEN moonage=moonage+360.0 moonphase=0.5-COS(TO_RAD*moonage)/2.0 moonage=Synmonth*moonage/360.0 END SUB[/quote] |
Try this Untested Jim VK7JH MMedit |
Only glanced at it but the syntax is all wrong in the IF statements. You have stuff like if moonage > 2.75 < 4 then but that makes no sense, It should be if moonage > 2.75 and moonage < 4 then This long list of IFs is quite inefficient too... consider using SELECT ... CASE ... so the above would look like Select Case moonage Case 2.75 To 4 ... you can also dispense with a lot of the repetitive stuff by only taking action when you need to e.g. Select Case moonage Case 2.75 To 4 x$="Waxing Crescent" Case ... Case ... etc... End Select Text 280,310,x$, LB,4, 1, RGB(white) this is a lot faster as in your code each IF will be tested regardless of if you have already made a choice. With Select/Case the code doesn't execute the remainder of tests - it jumps out as soon as a decision has been made. The code is smaller and more compact by only having the Text.... on one line at the expense of a variable. Also, you have holes in your moon phase tests... consider this: if moonage > 24 < 26 then Text 280,310, "Waning Crescent" , LB,4, 1, RGB(white) endif if moonage > 26 < 28. then Text 280,310, "Waning Crescent" , LB,4, 1, RGB(white) endif [/code] what if moonage is exactly 26? |
| rave Newbie Joined: 24/02/2018 Location: United StatesPosts: 28 |
Here is MMBasic 4.5 program to display the moon phase: http://fruitoftheshed.com/MMBasic.MOON-BAS-lunar-calendar-with-graphics-and-simple-GUI.ashx Programmed for the colour maximite, the program displays the moon phase both in text and graphically, for dates after 1582. The arithmetic is rather straightforward, no complex astrophysics software was used. No attempt was made to take the time zone of the viewer into account, but that does not matter too much to just calculate the moon phase as a rough measure anyway. ' return days since 01-01-0001 without Julian calendar correction FUNCTION Days(d$) LOCAL d,m,y,a d = VAL(MID$(d$,1,2)) m = VAL(MID$(d$,4,2)) y = VAL(MID$(d$,7,4)) a = INT((14-m)/12) m = m+12*a y = y-a Days = 365*y+INT(y/4)-INT(y/100)+INT(y/400)+INT((153*m-457)/5)+d-306 END FUNCTION ' returns the moon phase for phase 0<=p<=4 FUNCTION MoonPhase$(p) IF p < 0.1 THEN MoonPhase$ = "New" ELSEIF p < 0.9 THEN MoonPhase$ = "Waxing Crescent" ELSEIF p < 1.1 THEN MoonPhase$ = "First Quarter" ELSEIF p < 1.9 THEN MoonPhase$ = "Waxing Gibbous" ELSEIF p < 2.1 THEN MoonPhase$ = "Full" ELSEIF p < 2.9 THEN MoonPhase$ = "Waning Gibbous" ELSEIF p < 3.1 THEN MoonPhase$ = "Third Quarter" ELSEIF p < 3.9 THEN MoonPhase$ = "Waning Crescent" ELSE MoonPhase$ = "New" ENDIF END FUNCTION d = Days(d$)+19 p = d/29.530588 p = p-INT(p) phase = 4*p PRINT MoonPhase$(phase) - Rob |
Ah, yes, I forgot to include the ATAN2 function. Here it is: Thanks I didn't mention changing that, as it was so easy to do :) It works brilliantly and it's accurate down to 0.001 of a Lunar day |
Ah, yes, I forgot to include the ATAN2 function. Here it is: Thanks I didn't mention changing that, as it was so easy to do :) Better using the function I wrote however, since it will never fail, while ATN(y)/ ATN(x) fails for x = 0... |
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
Here's a link that provides more information about phases of the Moon http://aa.usno.navy.mil/faq/docs/moon_phases.php |
