Local Time 19:37 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LOCAL problem.....
Posted: 01:58am 17 Apr 2018
Hi all.
QUESTION: With the LOCAL command for use in Sub's, can different subs have different LOCAL commands with the same variable name? I thought you could, but it it throwing a wobbly when I try:
  Quote  SUB SETUP_HC12
CPU 10
Const HC12=17 'HC12 SET line. (sleep/wake)
SetPin HC12,DOUT:Pin(HC12)=1 'HC12 SET line
Open "COM1:9600" as #1 'Default baud-rate for a new HC12 is 9600...
Pin(HC12)=0 'Enter command mode
Pause 50 'Wait for module to respond
Print "Now attempting to configure new HC12 module @ 9600 baud..."
Print
Print "<HELLO MODULE?> ";
SET_HC12(
"AT")
Print "<SET 1200 BAUD> ";
SET_HC12(
"AT+B1200")
Print "<SET CHANNEL 64(458.6MHz)> ";
SET_HC12(
"AT+C064")
Print "<SET FU4 MODE> ";
SET_HC12(
"AT+FU4")
Print "<SET 100mW OUTPUT> ";
SET_HC12(
"AT+P8");
Pause 250
Pin(HC12)=1 'Exit command mode - changes take effect now!
Print "DONE! Execute CHECK_HC12 to confirm settings."
Close #1
End SUB
SUB CHECK_HC12
CPU 10
LOCAL D$
Open "COM1:1200" as #1 '1200 baud now, as module should be programmed...
Print "QUERY MODULE:"
Print
Print #1,"AT+RX"
Print
Pause 1000
D$=
Input$(Loc(#1),#1)
Print D$
Print
Print "DONE."
Close #1
Pin(HC12)=1
End SUB
End
SUB SET_HC12(E$)
LOCAL D$,E$
Print #1,E$
Pause 150
D$=
Input$(Loc(#1),#1) 'Suck HC12 response from buffer
Print D$
Pause 150
End SUB
I am getting 'E already declared.' errors.
As one sub calls the other, D$ is throwing an error, but I figured you could have LOCAL D$,E$ in one Sub, and another LOCAL D$,E$ in another sub and it would not care - as they are local to the sub they are defined in, and vanish into the great RAM monster in the sky when the Sub ends.
Do I actually have that wrong?
If I change the string names to something else, no problem, so that is the workaround I am using for now.Edited by Grogster 2018-04-18
Phil23
Posted: 02:12am 17 Apr 2018
That's a bit Strange Grog,
I'd expect you could & this little bit of code works in DOS.
  Quote  Do
Sub1
Sub2
Pause 1000
Loop
Sub Sub1
Local N%
for n%=1 to 3
Print "Sub1 N=";n%
Next N%
End Sub
Sub Sub2
Local N%
for n%=1 to 3
Print "Sub2 N=";n%
Next N%
End Sub
Phil.Edited by Phil23 2018-04-18
Phil23
Posted: 02:17am 17 Apr 2018
This works too, when Sub2 is called while still in Sub1.
  Quote  Do
Sub1
'Sub2
Pause 1000
Loop
Sub Sub1
Local N%
for n%=1 to 3
Print "Sub1 N=";n%
Next N%
Sub2
End Sub
Sub Sub2
Local N%
for n%=1 to 3
Print "Sub2 N=";n%
Next N%
End Sub
Edit:- Still works if I call Sub2 before the NEXT N in Sub1 also.
Azure
Posted: 02:47am 17 Apr 2018
You are using E$ as the passed argument and a local variable.
Posted: 03:44am 17 Apr 2018
OH !!!!!!!!
How the hell did I miss that, for God's sake.......(rhetorical!)
All fixed.
Feeling a little silly now.
Azure
Posted: 04:19am 17 Apr 2018
Glad I spotted it first then.
Even more happy it is all working.
Posted: 05:06am 17 Apr 2018
I don't think you should be using 'CONST" in a SUB/FUNCTION
If it is a true CONST, it belongs in the main code with the GLOBALs
If not a true CONST, use a LOCAL variable
Phil23
Posted: 06:06am 17 Apr 2018
  Azure said   You are using E$ as the passed argument and a local variable.
Was pretty easy to look straight past that.
P&G Zero.
Azure One.
Posted: 06:32am 17 Apr 2018
@ Jim - I will take your comments about CONST under advisement. Yes, I will change that.
[Quote=Phil23]P&G Zero[/Quote]
I see what you did there.
Azure
Posted: 06:41am 17 Apr 2018
Lets not start any scoring, I am just a newbie to the MM and grogster designs some lovely boards .
Posted: 06:49am 17 Apr 2018
Very kind, but Azure does get an approval tick for noticing this one!
Chopperp
Posted: 11:09am 17 Apr 2018
You're way ahead in the number of Posts count though , Mr Grogster
ChopperP
