Local Time 11:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wrinkle in MMBasic Select... Case...
Posted: 06:45pm 16 Apr 2018
Hello All (but esp Geoff and Peter M)
I have discovered a small bug with an easy work-around in the Select Case construct.
When comparing a negative constant I get the following error
[18] Case -2
Error: Syntax 1
It seems the case statement is not correctly evaluating the argument of negative two. The work-around is simple enough:
Case 0-2
one for the list?
> ? mm.ver
5.0408
> ? mm.device$
Micromite MkII
Edited by CaptainBoing 2018-04-18
Posted: 09:15pm 16 Apr 2018
Good find, thanks.
I will fix it in the next beta.
Posted: 10:58pm 16 Apr 2018
@ Captain: Another one to squish.
