Local Time 11:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM SD Card Data Read
Chopperp
Posted: 11:58am 14 Apr 2018
Hi
I can Write & Read single variables OK to the SD card using OPEN FOR RANDOM & SEEK. But I am having a great deal of trouble reading more than one variable from the card.
I also store lots of data OK with OPEN FOR APPEND, so I assume one would use OPEN FOR INPUT to get data back but I have nor worked out how to do it. It is obviously simple but I am missing the plot some where. I only want to read two variables back again.
Any help appreciated.
The Appendix on Random File I/O looks rather complicated for more than one variable or record.
(Give me 6502 machine code any day )
ChopperP
Posted: 02:41am 15 Apr 2018
You can keep your 6502 code!
Assuming you are reading and writing at random locations within a file on the card, then you would read back from the file using:
OPEN "FILE.TXT" FOR RANDOM AS #1 (for example) - See page 23 of the MM+ manual.
That done, use SEEK to position the file pointer within the file to the byte you want to start reading from: SEEK #1,200 for example.
Now, read the byte(s) at the pointer location: D$=INPUT$(5,#1), which will read in five bytes from byte 200, and stick them into D$ in this example. MMBASIC will increment the file pointer by however many bytes you want to read, but I THINK that the pointer will return to whatever you last set it to following the read - you would need to test that.
Chopperp
Posted: 02:51am 15 Apr 2018
Thanks Groggs. Will see if that works on the CMM later today.
ChopperP
Posted: 02:56am 15 Apr 2018
Oh, I missed the bit about the CMM....
Hopefully though, SD card access is pretty standard across all the versions. (false logic?)
Chopperp
Posted: 12:45pm 15 Apr 2018
I knew it was easy but took a long while to get something working.
In a nutshell
Storing:
Open file for RANDOM AS # whatever
Seek #, position 1
Print Data1
Seek #, position 2
Print Data2
Close #
Retrieving:
open again
seek # position 1
input #, Data1
seek # position 2
input #, Data2
close #
ChopperP
