Local Time 19:51 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Divide by Zero Error?
Phil23
Posted: 02:40am 09 Apr 2018
Can't understand how I'd get that error occasionally on this line of code that I'm using in the IEEE conversion for reading Modbus Energy meters.
[Code][82] Ans!=((Reading% Or &h800000) And &hffffff)/2^(23-Expo%)*(-1)^Sign% 'Extract Mantissa & Add implied 24th bit, Shift Point in Binary & apply sign
Error: Divide by zero
[/code}
2^0=1, so not that.
-1^0=1 & -1^1=-1.
It is probably corresponding to the meters display showing 0 Watts.
Any Suggestions?
Phil.
Posted: 02:57am 09 Apr 2018
Split the line up a bit
x! = 2^(23-Expo%)
y! = (-1)^Sign%
z! = ((Reading% Or &h800000) And &hffffff)
print x!, y!, z!
Ans! = z/x*y
It might show you where the problem is.
You might be getting caught with integers rounding to zero.
Phil23
Posted: 03:39am 09 Apr 2018
Thanks Jim,
Good thought.
2^?? might become to small to be a non-zero value of ?? gets too big in the negative direction.
Phil.
Phil23
Posted: 04:24am 09 Apr 2018
You were spot Jim,
Trapped it with this.
  Quote  Function Bin2Flt(ResStr As String) As Float
IeeeStr$=
"&H"+Mid$(ResStr, 7,8)
'Print IeeeStr$
Reading%=
Val(IeeeStr$)
Sign%=Reading% >>
31 'Read the Sign Bit
Expo%=((Reading% >> 23) And &hff) - 127 'Extract Exponent, Remove sign, Subtract Offset
If 2^(23-Expo%)*(-1)^Sign% = 0 Then
Print "Exponent: ";Expo%; " Sign: "; Sign%
End If
Ans!=((Reading%
Bin2Flt=Ans!
[Code]Response:- Exponent: -127Sign: : 0
[86] Ans!=((Reading% Or &h800000) And &hffffff)/2^(23-Expo%)*(-1)^Sign% 'Extract Mantissa & Add implied 24th bit, Shift Point in Binary & apply sign
[/code]
And the Dos Version proves this.
[Code]> print 2^-127
5.877471754e-39
> i%=2^-127
> print i%
0
>[/code]
Phil.
Edited by Phil23 2018-04-10
Posted: 04:33am 09 Apr 2018
  Quote   PRINT "n","Float","Integer"
FOR n = 10 TO -10 STEP -1
x! =
2^n
y% =
2^n
PRINT n, x!, y%
NEXT n
DOS MMBasic Ver 5.04.09 Beta 11
Copyright 2011-2018 Geoff Graham
n Float Integer
10 1024 1024
9 512 512
8 256 256
7 128 128
6 64 64
5 32 32
4 16 16
3 8 8
2 4 4
1 2 2
0 1 1
-1 0.5 1
-2 0.25 0
-3 0.125 0
-4 0.0625 0
-5 0.03125 0
-6 0.015625 0
-7 0.0078125 0
-8 0.00390625 0
-9 0.001953125 0
-10 0.0009765625 0
When the conversion from Integer to Float happens varies between programming languages and often bites you on the bum.
Phil23
Posted: 05:47am 09 Apr 2018
Hmmm,
Wonder how to best patch my code as at the moment I'm not using a 1 then the mantissa after the decimal with the exponent added.
Instaead I'm putting the one on the front to make a whole number integer & dividing that by the shifted exponent shifted to get the floating value.
It's reporting correct values for all the ranges I've tested, but will obviously fall over with a number that is divided by less than / 2^-2.
Phil.
Phil23
Posted: 05:53am 09 Apr 2018
I suppose the question is at what point in my function should I switch from itegers to floats.
Can't do the binary math on the floats, so would need to be after that.
Phil.
Posted: 06:35am 09 Apr 2018
Create 3 local variables as floats and do the maths in stages as in my previous post.
x! = 2^(23-Expo%)
y! = (-1)^Sign%
' print x!, y!, z!
Ans! = z/x*y
