Local Time 20:05 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Tx CFunction
RyanHammond
Posted: 02:13am 06 Apr 2018
In the included PDF for the SerialTx function, it states...
The SerialTx subroutine (created by adding the above code) takes three parameters:
SerialTx( pin, baud-rate, string )
Where pin is the I/O pin
baud-rate is the desired transmit speed
string is the string of characters to send
And the example...
SerialTx 2, 19200, "Hello World"
Does this mean you can't use a string variable like
SerialTx 2, 19200, A$
This could possibly make me weep a bit...
Posted: 03:50am 06 Apr 2018
No need to weep, you most definitely CAN use a string. I do it all the time using the TXD Cfunction.
That is just an example.
I use this in my code: TXD(TX,BAUD,TXT$)
I have renamed 'SerialTx' to TXD, but the idea is the same. TX is the pin I want the serial sent on, BAUD is the baud-rate(obviously), and TXT$ is the string to send.
Posted: 06:04am 06 Apr 2018
In the documentation string means a string variable, string constant or any expression which returns a string - the are all a string. Same for integer and float.
As Grogs said, that was just an example of one type of a string.
Posted: 07:45am 06 Apr 2018
It works fine as you need. I use it for my LPrint work-a-like. Couldn't stomach using up a complete serial port where all I need is a single pin... This CFunction is just the ticket.
I used the RX counterpart for reading a load of distance sensors that are free-running with a serial output (not the conventional trigger/response type). Just three normal pins and didn't consume any COM port.Edited by CaptainBoing 2018-04-07
