Local Time 20:18 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COM on MMX 144 pin
frederic
Posted: 03:11pm 31 Mar 2018
Hi everybody,
i am checking MMX144 on my own board....
i find problem with serial COM :
here is my little code :
debut:
open "COM2:4800" as #5
print #5,"hello"
close #5
pause 10
GoTo debut
nothing on TXpin except a little pulse (of course every 10mS)
i tried on COM1 and COM3, same problem, same little pulse,
i tried this code on another board MM+, and it is working well,
someone got this problem ?
fred
Posted: 03:27pm 31 Mar 2018
The MMX uses different libraries to the MM+. You are closing the port before the transmit has happened and the MMX is doing exactly what you asked.
You can use the LOF function to test for transmit complete before you close the channel. This will return the size of the transmit buffer once it is empty
frederic
Posted: 03:38pm 31 Mar 2018
of course !!
a little head i have!!!
so quick
many thanks
