Local Time 20:05 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DEX Help
Chopperp
Posted: 09:26am 30 Mar 2018
Updated DEX twice today.
Does any one who uses this program in Schematic mode have the problem of the "Snaps Per Grid" reverting to previous values when "CRT-Z" is used to undo a step. I can set a default value in Settings (2) but always goes back to previous values & ends up at 10. Most annoying
ChopperP
ChopperP
Posted: 09:40am 30 Mar 2018
Hi Chopper,
I thought in Schematic mode there wasn’t any snaps per grid.. that was a pcb setting..
I will check for you tomorrow though.
Chopperp
Posted: 10:37am 30 Mar 2018
Thanks Mick,
I mainly use DEX for doing basic electrical/electronic drawings
ChopperP (Chopper is OK)
ChopperP
Posted: 07:01am 31 Mar 2018
GDay Chopper,
I cant seem to change the snaps per grid at all in SCHEMATIC it is always 2 snaps per grid (which suits me)..
No matter what I do I cannot change it (even in settings for schematic)..
Sorry you may have better luck if you post your question the DEX Forum
Failing that a bug report by clicking the praying mantis in the help section.
Chopperp
Posted: 07:18am 31 Mar 2018
Hi Mick
Can you just do a change from 2 to 4 then do a control-Z & see if it goes back to 2 please?
Chopper
ChopperP
Chopperp
Posted: 07:46am 31 Mar 2018
Hi Mick again
Looked at the DEX forum. Too much for me.
It does appear that DEX remembers the grid setting at the time of the change. If you undo something, it goes back to that setting. Mine comes up as 2 now, not 10 as before, so I'll leave it at that.
Thanks again
Chopperp
ChopperP
