Local Time 20:18 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error: Justification
palcal
Posted: 12:37am 25 Mar 2018
  Quote  [9] Text MM.HRes/2,MM.VRes-160,T$,"` ",H$,"%",CMU,5
>I am getting the above error and don't know what it means.
When I was getting the display set up I was using
  Quote  [9] Text MM.HRes/2,MM.VRes-160,"35` 75%",CMU,5
and it worked OK, but now I have put the variables in in won't work.
I bought an E-Ink display but it is too slow to use for most things so I thought I would make a simple Temperature Humidity Display that would only need updating every ten minutes or so. The display cost $35 so I have to use it for something.
PaulEdited by palcal 2018-03-26
twofingers
Posted: 12:50am 25 Mar 2018
Hi Paul,
please try
  palcal said   Text MM.HRes/2,MM.VRes-160,T$+"` "+H$+"%",CMU,5
that should work.
  Quote  The display cost $35 so I have to use it for something.
Kind Regards
Michael
The lone and ...
palcal
Posted: 12:59am 25 Mar 2018
Of course, how stupid of me. When you are not coding all the time it is so easy to forget.
Paul.
