Local Time 20:19 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic 4.5b bug & crash
rave
Posted: 12:49am 22 Mar 2018
Thanks for the excellent MMBasic 4.5b implementation, which I'm running on a Colour Maximite project. So far things are working out and I am looking forward to contribute some MMBasic code soon.
I found an annoying bug in MMBasic 4.5b (I believe 4.5b is the latest version that I can flash to the CMM). I have a simple function IsMatch that matches strings in a certain way and returns 1 on success.
Here is my problem:
> ? IsMatch("a","a")
1
> ? IsMatch("a","(")
Error: Expected closing bracket
> ? IsMatch("a",")")
... the screen goes blank and the interpreter crashes ...
It appears that any string with a parenthesis in it that is used as an argument in a user-defined function causes an error or a crash
The problem is not caused by the IsMatch function, I tried different ones, here is an example:
function IsMatch(a$, b$)
IsMatch = a$ = left$(b$, len(a$))
end function
- Rob
Posted: 01:42am 22 Mar 2018
There is a V4.5C available from this thread:
https://www.thebackshed.com/forum/forum_posts.asp?TID=6772&PN=2&TPN=2
Halfway down the second page.
Posted: 02:25am 22 Mar 2018
Yes, it is a bug. It only occurs in string constants so you could use a variable containing ")" or chr$(41). The same for "(".
Sorry to say that V4.5C does not fix it.
twofingers
Posted: 10:46am 22 Mar 2018
@Geoff,
I guess for the TFT-Maximites and the Duinomites is no v4.5C available?
Michael
The lone and ...
Posted: 12:35pm 22 Mar 2018
No, not at this time.
twofingers
Posted: 12:46pm 22 Mar 2018
Thanks!
The lone and ...
