Local Time 14:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IF THEN ELSE ELSEIF not working
lew247
Posted: 10:27am 10 Mar 2018
For some reason I cannot get a subroutine to work
I am parsing data from an ESP8266 the parsing routine is working fine.
The data being sent from the ESP8266 always starts with either
STX1 STXR STXR STXV so I know what the data that follows is
I want the data from the line beginning
STX1 to go to T1
STXR to go to T2
STXP to go to T3
STXV to go to T4
The ONLY way I can get it to work is this sub - but it's no good because it's collecting all the data no matter what the data begins with instead of each data going to separate subs they are all being processed by T1
[quote]
Sub SERIAL2 'Com2 ESP8266 Weather Forecast
LOCAL N as INTEGER
N=GetFieldArray(ESP$)
IF FieldArray$(0)="STX1" T1 'If the 1st array is "STXT" then GOSUB T1
ENDIF
IF FieldArray$(0)="STXR" T2 'If the 1st array is "STXR" then GOSUB T2
ENDIF
IF FieldArray$(0)="STXP" T3 'If the 1st array is "STXP" then GOSUB T3
ENDIF
IF FieldArray$(0)="STXV" T4 'If the 1st array is "STXV" then GOSUB T4
ENDIF
End Sub[/quote]
The codes I have tried are
[code]Sub SERIAL2 'Com2 ESP8266 Weather Forecast
LOCAL N as INTEGER
IF FieldArray$(0)="STX1" then 'If the 1st array is "STXT" then GOSUB T1
T1
ELSEIF FieldArray$(0)="STXR" then 'If the 1st array is "STXR" then GOSUB T2
T2
ELSE FieldArray$(0)="STXP" then 'If the 1st array is "STXP" then GOSUB T3
T3
ELSE FieldArray$(0)="STXV" then 'If the 1st array is "STXV" then GOSUB T4
T4
ENDIF
End Sub[/code]
LOCAL N as INTEGER
T1
ENDIF
T2
ENDIF
T3
ENDIF
T4
ENDIF
End Sub[/code]
LOCAL N as INTEGER
T1
T2
IF FieldArray$(0)="STXP" then 'If the 1st array is "STXP" then GOSUB T3
T3
IF FieldArray$(0)="STXV" then 'If the 1st array is "STXV" then GOSUB T4
T4
ENDIF
ENDIF
ENDIF
ENDIF
End Sub[/code]Edited by lew247 2018-03-11
Posted: 10:54am 10 Mar 2018
You have a comment inside the command which overrides the rest of the line. Also IF THEN GOSUB is a single line command and doesn't need ENDIF
Try
LOCAL N as INTEGER
IF FieldArray$(0)="STX1" then GOSUB T1 'If the 1st array is "STXT" call T1
IF FieldArray$(0)="STXR" then GOSUB T2 'If the 1st array is "STXR" call T2
IF FieldArray$(0)="STXP" then GOSUB T3' If the 1st array is "STXP" call T3
IF FieldArray$(0)="STXV" then GOSUB T4 'If the 1st array is "STXV" call T4
End Sub
Slightly more efficient using multiline format
LOCAL N as INTEGER
ELSE IF FieldArray$(0)="STXR" then
ELSE IF FieldArray$(0)="STXP" then
ELSE IF FieldArray$(0)="STXV" then
ENDIF
End Sub
Edited by matherp 2018-03-11
lew247
Posted: 01:58pm 10 Mar 2018
Thanks Peter
Posted: 02:26pm 10 Mar 2018
SELECT CASE is an alternative option available. I personally like this one as it makes easy reading at a later date!
@Peter/@Geoff - Is there any speed advantage/dis-advantage between CASE and IF/THEN?
LOCAL N as INTEGER
SELECT CASE FieldArray$(0)
CASE "STX1"
CASE "STXR"
GOSUB T2. 'If "STXR" call T2
CASE "STXP"
GOSUB T3 'If "STXP" call T3
CASE "STXV"
GOSUB T4 'If "STXV" call T4
END SELECT
End Sub
Edited by WhiteWizzard 2018-03-12
Posted: 03:32pm 10 Mar 2018
  WhiteWizzard said  Is there any speed advantage/dis-advantage between CASE and IF/THEN?
No, both of them perform roughly the same. Generally IF/THEN is more convenient for simple decision trees while SELECT/CASE works better for complex cases. It is a matter of taste.
GeoffEdited by Geoffg 2018-03-12
lew247
Posted: 12:46pm 16 Mar 2018
Thanks everyone, I solved the problem by just having one string coming from the ESP8266.
I do have a 2nd problem now though which is related
The idea of the SUB is IF a section of the weather data is missing instead of it being printing "not found" to the screen it prints one or 2 characters instead, that way the screen doesn't mess up
The MM does get as far as the SUB, I put a test print in there to check but the SUB just gets ignored.
[code]SUB CHECKARRAY 'Sub to check for "NOT FOUND" and replace with "" so display does not mess up
print "I got here"
if temp2$ = "Not Found" THEN
temp2$ = "00"
end if
if icon$ = "Not Found" then
icon$ = "50n"
if temp1$ = "Not Found" THEN
temp1$ = "00"
end if
IF press1$ = "Not Found" THEN
press1$ = "00"
end if
if speed$ = "Not Found" THEN
speed$ = "00"
end if
angle1$ = "Not Found" THEN
angle1$ = "360"
end if
if hum1$ = "Not Found" THEN
hum1$ = "00"
end if
if tempmin$ = "Not Found" THEN
tempmin$ = "00"
end if
if tempmax$ = "Not Found" THEN
tempmax$ = "00"
end if
if hum2$ = "Not Found" THEN
hum2$ = "00"
end if
if vis$ = "Not Found" THEN
vis$ = "00"
end if
if desc0$ = "Not Found" THEN
desc0$ = "00"
end if
if rain44$ = "Not Found" THEN
rain44$ = "00"
end if
if press2$ = "Not Found" THEN
press2$ = "00"
end if
if uv$ = "Not Found" THEN
uv$ = "00"
end if
if tempmin1$ = "Not Found" THEN
tempmin1$ = "00"
end if
if tempmax1$ = "Not Found" THEN
tempmax1$ = "00"
end if
if rain$ = "Not Found" THEN
rain$ = "00"
end if
if tt1$ = "Not Found" THEN
tt1$ = "00:00:00 "
ENDIF
if dow1$ = "Not Found" then
dow1$ = "***"
end if
if dm1$ = "Not Found" then
dm1$ = "00:JAN"
end if
if Year$ = "Not Found" then
Year$ = "1900"
end if
END SUB[/code]
This SUB just does not work, it gets ignored.
Any idea why?
lew247
Posted: 03:58pm 16 Mar 2018
I "might" have it sorted.
Trying [code] "Not" + CHR$(32) + "Found" THEN[/code]
I have to wait for the "not found" to actually be sent before I know if it's working or not
EDIT: It Didn't work - back to the drawing boardEdited by lew247 2018-03-18
Posted: 08:52pm 16 Mar 2018
Does the "not found" always have the same case?
"Not Found" is different to "Not found"
Are there any leading or trailing space characters?
To fix the case problem I use UCASE$
rain$ = "00"
end if
becomes
if UCASE$(rain$) = "NOT FOUND" THEN
rain$ = "00"
end if
etc
or
if INSTR(UCASE$(rain$),"NOT FOUND") = 0 THEN
rain$ = "00"
end if
to cover any leading or trailing spaces
lew247
Posted: 09:49pm 16 Mar 2018
Thanks Jim,
I'll give that a try but I#m going to have to try and find an sd card socket somewhere locally, the one of the back of my display is not detecting the card anymore
I've changed cards in case it was the card
Posted: 12:21pm 17 Mar 2018
there are two errors in your code where bits are missing, marked ######## in the below:
print "I got here"
temp2$ = "00"
end if
icon$ = "50n"
temp1$ = "00"
end if
press1$ = "00"
end if
speed$ = "00"
end if
######## angle1$ = "Not Found" THEN
angle1$ = "360"
end if
hum1$ = "00"
end if
tempmin$ = "00"
end if
tempmax$ = "00"
end if
hum2$ = "00"
end if
vis$ = "00"
end if
desc0$ = "00"
end if
rain44$ = "00"
end if
press2$ = "00"
end if
uv$ = "00"
end if
tempmin1$ = "00"
end if
tempmax1$ = "00"
end if
rain$ = "00"
end if
tt1$ = "00:00:00 "
ENDIF
dow1$ = "***"
end if
dm1$ = "00:JAN"
end if
Year$ = "1900"
end if
END SUB
you should also be indenting your code and adding blank lines to make it more readable. i would also suggest changing all the if-then statements in this particular subrouting to their single-line versions to improve readability:
print "I got here"
if temp2$ = "Not Found" THEN temp2$ = "00"
if icon$ = "Not Found" then icon$ = "50n"
if temp1$ = "Not Found" THEN temp1$ = "00"
IF press1$ = "Not Found" THEN press1$ = "00"
if speed$ = "Not Found" THEN speed$ = "00"
IF angle1$ = "Not Found" THEN angle1$ = "360"
if hum1$ = "Not Found" THEN hum1$ = "00"
if tempmin$ = "Not Found" THEN tempmin$ = "00"
if tempmax$ = "Not Found" THEN tempmax$ = "00"
if hum2$ = "Not Found" THEN hum2$ = "00"
if vis$ = "Not Found" THEN vis$ = "00"
if desc0$ = "Not Found" THEN desc0$ = "00"
if rain44$ = "Not Found" THEN rain44$ = "00"
if press2$ = "Not Found" THEN press2$ = "00"
if uv$ = "Not Found" THEN uv$ = "00"
if tempmin1$ = "Not Found" THEN tempmin1$ = "00"
if tempmax1$ = "Not Found" THEN tempmax1$ = "00"
if rain$ = "Not Found" THEN rain$ = "00"
if tt1$ = "Not Found" THEN tt1$ = "00:00:00 "
if dow1$ = "Not Found" then dow1$ = "***"
if dm1$ = "Not Found" then dm1$ = "00:JAN"
if Year$ = "Not Found" then Year$ = "1900"
END SUB
rob :-)
Paul_L
Posted: 11:07pm 17 Mar 2018
If you load your code from your post of 3/16 at 7:46 am into the extremely helpful MMEdit code editor and then select <P>rogram, <F>ormat you will instantly see an indented version of your code with vertical lines showing how all the IF ... ENDIF, DO ... LOOP, SUB ... END SUB, and other structures are paired.
This will make the missing chunks of structure that Rob spotted above much more obvious. I definitely agree that sometimes the single line IF ... THEN structure can be much clearer.
Stop tearing your hair out, use MMEdit to format your code!
Paul in NY
lew247
Posted: 11:16pm 17 Mar 2018
I always use MM Edit
I actually didn't know it could do that....
lew247
Posted: 03:51pm 28 Feb 2019
A strange problem
[code] if val(prob$) > 0 then
Text 70,750, prob$ "% chance of "+type$, LB, 4, 1, RGB(BLACK),RGB(WHITE)
end if
print val(prob$), "Val"[/code]
Result is
0.28 Val
but the text line does not print
I've even changed the 0 to 0.00 and it still won't print the text
Edit: latest version of Picromite is what I'm using
Edit2
I changed it to
[code] val1 = val(prob$) * 100
print val1
if val1 > 2 then
end if
Still does the same other than val1 = 28 which is correct but the if/then still doesn't work
Edited by lew247 2019-03-02
Posted: 04:09pm 28 Feb 2019
Should be a "+" between prob$ and "%...
lew247
Posted: 04:13pm 28 Feb 2019
Thank you Peter I definitely owe you many beers or whatever else you drink
and thanks to WhiteWizzard who told me about multiplying the number to make it greater than 0.5Edited by lew247 2019-03-02
