Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Array initialisation
f2cf1g
Posted: 05:45pm 11 Feb 2018
I need to initialise a lookup table of 120-odd integer elements. I can't put the initialisation values one line nor can I split it over several lines. The only method that I can think of is to write some code to load multiple DATA statements into the array during initialisation. I'm new to MM Basic and was wondering if there is a more elegant method of doing it?
Phil23
Posted: 09:26pm 11 Feb 2018
How many characters in each integer?
You ma be able to set a couple of string variables & read them in bit by bit in a loop using Val & Mid$.
Something a bit like this.
(Not sure the synatax is correct, but should give you the picture.
  Quote   Data1$="0001000200030004000500060007000800090010"
For n=1 to 10
p=n*
4-3
DArray%(n-
1)=Val(Mid$(Data1$,p,4)
Next n
Edit, DATA can probably also be imported with a similar loop.
Phil
Edit again..
Others might comment on if what's below would work.
  Quote   Data 0001,0002,0003,0004,0005,0006,0007,0008,0009,0010
For n=1 to 10
Read DArray%(n-1)
Next n
Edited by Phil23 2018-02-13
twofingers
Posted: 10:22pm 11 Feb 2018
Hi Roy,
maybe a job for Nathan's newest invention (simpleArrayFuncGen)?
This could save time and space (memory).
See also http://www.thebackshed.com/forum/forum_posts.asp?TID=10040.
Kind regards
Michael
f2cf1g
Posted: 12:01am 12 Feb 2018
I was afraid that the simplearraygeneration might be something relevant to my problem! Life is too short for that sort of complexity given I only have 120 numbers to deal with. I will use your second example Phil, with several data statements. Thanks both for you help.
Roy
