Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pic32 portspeed.
plasma
Posted: 05:31pm 11 Feb 2018
Hi ,
i need a info about the Portspeed for pic32 mx and pic32 mz.
how many pulses can it produce in full speed , in mmbasic and maybe in c or asm.
i have no chance to test this at the moment so i ask here for help.
thx
panky
Posted: 05:14am 12 Feb 2018
@plasma
Using a PIC32MX170 at 40MHz, the MMBasic Manual says using the PULSE command your can generate pulses a minimum of 5uS in MMBasic.
Extrapolate out to a PIC32MX470 running at 120MHz, you should be able to get down to somewhere around 2uS or a bit less Going to a PIC32MZ at 252Mhz should allow you to get down to something a bit less than 1uS.
No idea what C or Assembler could achieve but at 1 instruction per machine cycle, the MZ chip at 252MHz should be able to get down to something approaching 10nS pulses - this is entirely supposition
panky
