Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : XMODEM RECEIVE - "Remote did not respond"
rhiemann
Posted: 07:20pm 08 Feb 2018
I am using following lines with MM plus 5.0408 to transfer an image to my SD card.
Works quite well if remote is available.
OPTION ERROR CONTINUE
XMODEM RECEIVE "File.bmp"
If remote is not available (approx. after 30s) I get following error message and my program stops:
I am using this option
If I have issues with my SD card than I am able to handle the error with my code
IF MM.ERRNO<>0 THEN CtrlVal(TextStatus)= "ERROR"
Any idea how to handle this remote did not respond error?
Is there a way to define the wait time? By default it is approx. 30s.
Thanks in advance
Rico
Posted: 09:39pm 08 Feb 2018
Welcome to the forum Rico.
OPTION ERROR CONTINUE only applies to file I/O errors and this error is due to a communications timeout - which is why the error is not caught.
To catch this error you can use ON ERROR IGNORE or ON ERROR SKIP.
OPTION ERROR has been removed from the manual and in a future version will be removed from MMBasic. Its functionality has been replaced with ON ERROR which essentially does the same thing and can handle a wider range of errors (such as your timeout).
  Quote  Is there a way to define the wait time? By default it is approx. 30s.
Sorry, no.
