Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can’t order from DigiKey.....
Posted: 03:30am 08 Feb 2018
Is anyone else seeing this?
I can browse around just fine, and in the case of the tilt-switches I wanted to buy some of, I can see that they say they have 4,287 in stock - great!
Now, I login and try to add them to my cart, and the available quantity is now 'ERROR', and it simply won't let me add any to my cart, so I can't go any further.
I opened a chat with them, and went through all of this, and even they don't know what is going on, as it works fine for them, so they were saying.
Tried another browser, exactly the same problem. Cleared cookies, and logged in again, same problem.
Anyone else seeing that?
EDIT: I have managed to complete an order, but I had to add to cart what I wanted, and THEN login and complete - then it let me. Odd. Oh well. I bought three different types of tilt sensor to play with. One is another ball-type unit, but it is a gold-plated ball and contacts unit, so says the datasheet, so that alone might solve many of my problems, as the cheap ones from China were.....well......cheap ones from China. Edited by Grogster 2018-02-09
palcal
Posted: 04:19am 08 Feb 2018
I just tried Grogs and all was OK. BUT $1.99 for the part and $24 shipping.
Paul.
disco4now
Posted: 04:23am 08 Feb 2018
I can add to the cart from au site with no problem
https://www.digikey.com.au/product-detail/en/e-switch/TM1000Q/EG4917CT-ND/2498457
NZ OK too.
https://www.digikey.co.nz/product-detail/en/e-switch/TM1000Q/EG4917CT-ND/2498457
Maybe just a glitch. looks like it could not get the quantity avaiable when you went to order.
Gerry
F4 H7FotSF4xGT
See edit above, Paul.
By ordering several different sensors and 50 20MHz crystals, you get the total up to NZ$40 or so, and the shipping is then free.
So, 10x TM1000, 5x RPI1035, 10x RB22007AR and 50x crystal = $66 with free UPS shipping.
CYBERLAB
Posted: 04:26am 08 Feb 2018
hI Grogster, also with me everything is fine.
Posted: 04:27am 08 Feb 2018
Most strange.
palcal
Posted: 04:31am 08 Feb 2018
@ Grogster Farnell / Element14 also have them.
Paul.
hitsware
Posted: 04:49am 08 Feb 2018
For some reason I like Mouser ....
Posted: 05:45am 08 Feb 2018
@ palcal: Yes, I did notice that, but they are not in stock, and you have to buy 350 of them in one go! Not expected before June this year either.
Evidence.
@ hitsware: I also like Mouser. Should have tried them, but I have bought from DigiKey plenty in the past, and it always worked. Oh well. Edited by Grogster 2018-02-09
