Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SerialRx. and SerialTx.
lew247
Posted: 01:26pm 03 Feb 2018
I would like to change a couple of pins to be serial ports using the Embedded C code
I've been reading the PDF's about how to do this in the CFunctions section of the download but I'm a bit confused
If I wanted to change pin 23 and 39 to serial rx and tx could I do the following or not?
I "IDEALLY" want to do the following
but
I don't think it will work as it uses an interrupt and I "THINK" you can't do that if you don't use the real com ports?
I want to use the click board on the E100 to interface with the outdoor board but it only has one com port and I need 2
one for the ESP8266 and the other to talk to the outdoor board
[code]
Open "COM2:9600,1024,isr" As #1 'Open port for ESP8266
If head<>tail Then ' collect sentence from buffer
B$ = CB$(tail)
tail = (tail Mod 10)+1
EndIf
if B$<>"" THEN SERIAL1 ' if data GOSUB Serial1 ESP8266
B$ = ""
END IF
Sub isr ' serial port handler
Local I, S$ length 80
S$ = Input$(72,#1) ' grab data into temporary buffer
Z$ = Right$(Z$,255-Len(S$))+S$ ' add to end of linear buffer
I = Instr(Z$,Chr$(42)) ' check for eol marker (CR+LF)
If I<>0 Then
CB$(head) = Left$(Z$,I-1) ' transfer into circular buffer
head = (head Mod 10)+1
If I<254 Then Z$ = Mid$(Z$,I+2) Else Z$=""
EndIf
End Sub
SUB SERIAL1
Local N AS INTEGER
N = GetFieldArray(B$)
PRINT B$
IF FieldArray$(0) = "Today" THEN T1 'If the 1st array is "Today" then GOSUB T1
'IF FieldArray$(0) = "Day2" THEN T2 'If the 1st array is "Day2" then GOSUB T2 'If the 1st array is "Day2" then GOSUB T2
'IF FieldArray$(0) = "Day3" THEN T3 'If the 1st array is "Day3" then GOSUB T3
'IF FieldArray$(0) = "Day4" THEN T4 'If the 1st array is "Day4" then GOSUB T4
END IF
END SUB[/code]Edited by lew247 2018-02-04
Posted: 02:15pm 03 Feb 2018
I don't really understand what you are trying to do but the bottom line is that you cannot change the pins allocates to serial I/O. For COM1 they are fixed in hardware and for COM2 they are fixed in the firmware.
However, if you use the serial I/O CFunctions you can use whatever pins that you want to. But then you must call the CFunction, not normal serial I/O (COM1, etc).Edited by Geoffg 2018-02-05
lew247
Posted: 02:38pm 03 Feb 2018
SerialRx
This is a CFunction module which can add any number of serial input ports to the Micromite.
SerialTx
This is an embedded C module which can add any number of serial output ports to the Micromite.
I want to make 2 of the pins on the E100 Click Board into Com 1 or 2
but it has to be able to be used as an interrupt on receiveEdited by lew247 2018-02-05
Posted: 02:41pm 03 Feb 2018
As Geoff says, you can't.
Instead you could do essentially what you want but must only use the CFunctions for that extra serial I/O.
Posted: 02:55pm 03 Feb 2018
You can have as many SerialTx pins (i.e. ordinary digital output) as you have available on the chip.
You can have as many SerialRx pins (i.e. ordinary digital input) as you have available on the chip.
What you cannot do is to call them COM1,2,3,4,.....
Remember serial data is just up and down pulses of data with specific timings. traditionally it was reasonably tricky to do this yourself so chip manufacturers started putting hardware modules (called USARTs) on the chip and these integrtaed with everything else and took care of all the timings etc.
SerialTx/Rx are simply two routines that synthesize these pulses in the right patterns to any pin you like, however as a generalization, the USARTs in the micromite (COM1, COM2)are still dedicated to specific pins of the PIC32 and you can't point them somewhere else.
So to make a makeshift Com port at 9600 on pin 23, use SerialTx like so
SerialTx(23,9600,"Hello world"+chr$(13)+chr$(10))
pin 23 at 9600 bits/s message string. chr$(13)+chr$(10) is the newline sequence and most equipment will expect it
SerialRx is the same deal with a few controls (data length and timeout)
If you wanted you could do this to make you feel more comfortable:
Const COM8 = 23
SerialTx(COM8,9600,"Hello world"+chr$(13)+chr$(10))
These two CSubs are very good - I have used them often and they work nicely. I use them when I am only interested in one-way comms - I can't stomach using a whole COM port if I am never using the Rx side of it or similar.Edited by CaptainBoing 2018-02-05
lew247
Posted: 02:56pm 03 Feb 2018
I dont get it
IF I wanted to use for example on the Explore 100 Pin 27 as Com5 TX and 82 as Com 5 RX
could I do this? and use pin 82 as an interrupt? and then go to a subroutine on interrupt?
Would this work?
From the instructions it says
You receive data simply by using the SerialRx function. For example:
r = SerialRx( 2, 19200, s$, 1000 )
This to me says it cannot be done
IF it cant be done, How can I tell the micromite to monitor the serial rx and do something if it gets an input?
EDIT this was written before the last post got posted*
I'm still not sure if I can use it as an interrupt or notEdited by lew247 2018-02-05
Posted: 03:14pm 03 Feb 2018
You cannot "divert" any of the built in com pins, nor make up your own and expect OPEN to understand them.
your point about the interrupt is an idea though... serial lines normally sit HI when idle. When comms is about to start, it goes LO for 1 bit width (the start bit) then the data starts rattling in then at last the pin goes (or stays) HI for (usually) 1 bit width (the stop bit).
I am guessing you could configure the new serial pin (lets say 23) as an input with an interrupt on LO. When you get to your interrupt routine - this would be your serial receive section where you would have your SerialRX and a decent timeout... I wonder if SerialRX would be OK with not getting a full start bit (some time would be lost as you respond to the initial LO and reconfigure until you are finished receiving)...
I haven't tested it but maybe something like this:
in your setup
SetPin 23,DIN,INTL,SerialISR
then your serial routine
Sub SerialISR
SetPin 23,DIN
r=SerialRx(23,9600,s$,1000)
' snag your data
'set up for interrupt next time
End Sub
you might just get away with it if you lower the baud rate to within the tolerance of the timings (so the lost section of the start bit could be excused)
EDIT: Actually I don't think this will work - I am pretty certain SerialRX will need to see the HI-to-LO transition to get all it's timings right.
Posted: 01:00am 04 Feb 2018
The MM COM ports are fixed, as Geoff says.
COM1 and COM2(and COM3 and COM4 on the MM+) chip are dedicated serial ports with special features such as interrupts and buffers.
The CSub serial ports are a software bit-banged serial stream, but cannot do anything other then send(the SerialTX CSub) or receive(the SerialRX CSub) a serial stream AT THE INSTANT THEY ARE CALLED. They have no buffering or ability to set off an interrupt.
The native COM ports are fixed. You cannot change the pin numbers they operate on or otherwise assign them somewhere else. The bit-banged CSub serial ports can use any pins you like, but they are not referred to in code as a 'COM port' per-se.
See this example code I have here, which uses the transmit CSub:
  Quote   If Loc(#2) Then '----------Message from HC12 module------------
Pin(LED_HC12)=1
Pause 250 'Allow all of data packet to arrive from HC12 module
D$=Input$(20,#2) 'Suck data packet from HC12 buffer
If Pin(SMC)=0 Then D$=D$+Chr$(13) 'Add <CR> byte if SMC jumper on
Print "HC12: ";D$ '...otherwise just forward message without <CR>
Pause DELAY/2
Pin(LED_HC12)=0
TXD(TXO,BAUD,D$)
EndIf
...and the CSub that is used with the above is the standard one, that I have just renamed to suit my purposes:
  Quote  CSub TXD 'TXD (PIN,BAUD,STRING)
00000008
00001021 40824800 40024800 0044102b 1440fffd 00000000 03e00008 00000000
27bdffc8 afb40020 3c149d00 8e820000 afb00010 8c500000 8ca30000 00108042
0203001b 006001f4 afb10014 8e820010 00808821 8c840000 afbf0034 afb60028
afb3001c afb20018
00c0b021 24050008 00003021 afbe0030 afb7002c afb50024
0040f809 00008012 8e240000 8e820014 0040f809 24050001 8e240000 8e820024
0040f809 24050006 00409021 8e240000 8e820024 0040f809 24050005 00409821
8e240000 8e820028 0040f809 2610fffb 82c30000 18600027 24110001 00518804
24150001 ae710000 02002021 0411FFC4 00000000 241e0008 24170001 10000009
02d5a021 ae510000 02002021 0017b840 27deffff 0411FFBA 00000000 13c0000d
32f700ff 82820000 02e21024 1440fff5 00000000 ae710000 02002021 0017b840
27deffff 0411FFAE 00000000 17c0fff5 32f700ff ae510000 02002021 0411FFA8
00000000 82c20000 02a2102a 1440ffdd 26b50001 8fbf0034 00001021 00001821
8fbe0030 8fb7002c 8fb60028 8fb50024 8fb40020 8fb3001c 8fb20018 8fb10014
8fb00010 03e00008 27bd0038
End CSub
In my case, the serial is output in this line: TXD(TXO,BAUD,D$), where TXD is the name of the CSub, TXO is the transmit-output pin for the serial data to be output, BAUD is the baud-rate, and D$ is the data to output.
The native COM ports will return IMMEDIATELY when you send data, leaving the buffer to take care of sending the data for you so your program can get back to doing it's thing without waiting for the serial port.
The CSub will NOT return until all the data has been sent, so using the CSub can and will generate small delays while the data is clocked out of the nominated pin.
Hope that helps clarify it it a little more.
EDIT:
[Quote=lew247]IF it cant be done, How can I tell the micromite to monitor the serial rx and do something if it gets an input?[/Quote]
You can't. Not with the CSub's/Cfunctions you can't.
What you CAN do, is setup and interrupt that CALLS the SerialRX Cfunction, and use the timeout feature of the SerialRx Cfunction.
Something like this:
SetPin 82,INTL,RXD
...then have your interrupt call the Cfunction like this:
[Code]
SUB RXD
DUMMY=SerialRX(82,9600,D$,250)
END SUB
[/Code]
...then you can check if there is anything in D$ as part of your main loop or whatever - IF D$ THEN.... kind of idea.
That SHOULD work, but I have a feeling the first byte might be corrupted, as the Cfunction would miss the first bit of the first byte, reacting to the interrupt.
If you CAN spare another I/O pin as an interrupt, then you could use THAT instead of pin 82 for your SetPin command. Then the external interrupt line can trigger the SerialRX Cfunction via the SUB. That should catch just about anything, PROVIDED the external source of the data can supply an interrupt line for you to tell the MM that it needs to call the SerialRX Cfunction if you catch my drift.
If you absolutely MUST have 100% monitored serial input, and you have used your native COM ports, then you really need another chip. The PICAXE 8-pin chip is a marvellous COM port buffer, as it's PICAXE-BASIC code will WAIT for the prescribed data to arrive before sending anything on. Used with a qualifier, the PICAXE 08 makes a beautiful data-filter/receiver, is small and cheap. Something else to think about.
Edited by Grogster 2018-02-05
lew247
Posted: 08:18am 04 Feb 2018
Thanks, that explained it perfectly
lew247
Posted: 08:21am 04 Feb 2018
Just looking at the Picaxe 8
How could you use that in conjunction with the MM?
I don't get Used with a qualifier, the PICAXE 08 makes a beautiful data-filter/receiver
Posted: 10:01am 04 Feb 2018
Oh, right, probably should have elaborated a bit on that - sorry.
With the PICAXE chips, the SERIN command can have a qualifier, which is just a pre-determined string of characters which MUST come before the main message. This can be anything you like.
An example using PICAXE BASIC on the 8-pin chip(08M2) would be:
serin 1,T2400,("ABCD"),b1,b2,b3,b4,b5
In that example, the PICAXE will wait forever until it gets "ABCD" FIRST, before it saves the next five bytes. See PICAXE BASIC COMMANDS manual, page 213.
An 08M2 data-filter I still use to this day is:
start:
serin 1,T2400,("ABCD") 'Sniff for qualifier
high 4 'Turn on LED
serin 1,T2400,b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13'Input message bytes
high 2
serout 2,T2400,("ABCD",b0,b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13,CR)'Send message bytes to PC
pause 150 'Delay for LED
low 4 'Turn off LED
goto start 'Do it again
In this example, the 08M2 chip waits forever for the qualifier BEFORE it then inputs the data bytes, and then forwards that along to the main system.
It was done this way, as the PICAXE was sitting on the output of a 'Dumb' RF receiver module, and when there is no data to output, the module just outputs garbage data representing the white-noise in the background. The PICAXE chip sits there and waits for the 'Real' data packet, then sends that along to the system, so the main system COM port does not fill up with white-noise.
This is an old code from 2010, so is crude but effective.
The M2 parts also have a hardware serial port that is buffered. See the HSERIN command, page 94 of the same commands manual. PICAXE chips call their hardware serial port buffer the 'Scratchpad'. HSERIN and HSEROUT commands do not allow for a qualifier though, which is why I used the plain old SERIN command above, but I felt I should mention that the M2 PICAXE parts also have a hardware serial port if speed is your thing.
EDIT: Just had a wee read of the PICAXE hardware serial commands, and on the M2 parts, the buffer is only two bytes deep, so essentially nothing. The X2 parts(starting with the 20-pin chip) have the 1k or so scratchpad memory(buffer).Edited by Grogster 2018-02-05
