Local Time 10:08 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Odd behaviour of MMBasic VAL() ?
Posted: 12:05pm 01 Feb 2018
In recent fiddlings, I have noticed some problems with the action of VAL(). It certainly looks like a bug but maybe I am misinterpreting things. I have checked the description of VAL in the manual but there is no mention of this kind of behaviour.
It seems to ignore characters for some reason and this affects its basic arithmetic (see example below) that VAL only returns the absolute value of binary and hex strings (probably octal as well but I didn't try) and has errors with different strings.
I was rather expecting a binary string of sixty three 1's and a zero to return a value of -2 but it doesn't, also a value of eight FF's should be -1:
> ? mm.ver
5.0408
> ? val("&b1111111111111111111111111111111111111111111111111111111111111110")
9223372036854775807
> ? val("&hffffffffffffffff")
9223372036854775807 <-- same value for different string
This exhibits the same behaviour if I assign the VAL to a variable (the value is not assessed correctly either):
> x%=val("&b1111111111111111111111111111111111111111111111111111111111111110")
> ? x%
9223372036854775807
> ? bin$(x%,64)
0111111111111111111111111111111111111111111111111111111111111111
However if I assign the same binary value directly, it behaves as I expected:
> x%=&b1111111111111111111111111111111111111111111111111111111111111110
> ? x%
-2
Any ideas?
Edited by CaptainBoing 2018-02-02
twofingers
Posted: 01:39pm 01 Feb 2018
  CaptainBoing said   Any ideas?
It smells like a bug. Get an exterminator. Edited by twofingers 2018-02-02
Posted: 02:15pm 01 Feb 2018
Good find, thanks.
VAL() works correctly for numbers of 63-bits or less but not with a 64-bit number. I will fix it in the next version.
Posted: 02:36pm 01 Feb 2018
  Quote   I will fix it in the next version.
What is the bug? I looked at the source and couldn't see anything obvious unless strtoll() is faulty
Posted: 10:30pm 01 Feb 2018
Yes, stroll() is faulty. The replacement is:
if(*p == '&') {
p++; iret = 0;
switch(toupper(*p++)) {
case 'H': while(isxdigit(*p)) {
iret = (iret << 4) | ((toupper(*p) >= 'A') ? toupper(*p) - 'A' + 10 : *p - '0');
p++;
break;
case 'O': while(*p >= '0' && *p <= '7') {
iret = (iret << 3) | (*p++ - '0');
break;
case 'B': while(*p == '0' || *p == '1') {
iret = (iret << 1) | (*p++ - '0');
break;
default : iret = 0;
