Local Time 21:14 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Diptrace Help
OA47
Posted: 09:05am 25 Jan 2018
I posted this on the PCB Manufacturing forum but thought I might get help here:
I have a double sided PCB in Diptrace and I am trying to link the ground pads of the 3T regs to the copper fill on the bottom of the PCB with vias for thermal purposes. Every time I try to achieve this I get errors in the DRC. Can anyone help with the right procedure to accomplish this?
OA47
Posted: 04:28pm 25 Jan 2018
If you place a via it is not connected to any net.
The way i do it is to put a bunch of via's next to the board.
Add them to the ground 'net'. (right click -> add to net)
I then place them one by one where i want them.
If you need more, just copy/paste them.
OA47
Posted: 11:19pm 25 Jan 2018
Thanks Jean, your advice lead me to success. My copper pour was not attached to a net, when attached all seems good.
Graeme
OA47
Posted: 11:45pm 25 Jan 2018
My success was short lived when I connect the pour to net 0, I lose my bottom tracks so back to the drawing board.
Posted: 03:26am 26 Jan 2018
Looks like your nets are not good anymore.
It can happen when you place a trace or via and you get a message if you want to combine nets or something similar.
To restore that you can synchronize your nets again with your schematics.
Under menu 'File' you choose 'Renew design from schematics'. First time you will need to choose the schematics file. After that you can use a keyboard shortcut Ctrl+Alt+U.
