Local Time 21:13 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite Extreme
OA47
Posted: 05:10am 25 Jan 2018
I have the need to come up with a controller such as the Micromite Extreme either 100 pin or 144pin and was wondering if there is anyone in Oz that could sell me a PCB that would do the job. I have both 100 and 144 chips on hand.
OA47
palcal
Posted: 05:52am 25 Jan 2018
I have some of these if that would help. Not exactly what you want. PM me if you want one.
I got my 100/144 PCBs from WW.
TFT Backpack V1.3
Paul.Edited by palcal 2018-01-26
OA47
Posted: 06:04am 25 Jan 2018
Thanks Paul. I was angling down the road of VGA output which I believe is only available with the 100 and 144 pin PICs.
I did look on Micromite.org but couldn't see the extreme PCBs. As usual I am in a bit of a hurry to test out a project so I thought I would see if there were any available here in Oz.
Graeme
P.S. By the date on my Forum screen it is already Oz Day Edited by OA47 2018-01-26
palcal
Posted: 06:30am 25 Jan 2018
OK If you don't need a TFT header I do have a spare SnadPic 100 pinner. No need for assembly.
Paul.
Frank N. Furter
Posted: 08:29am 25 Jan 2018
Hi Paul,
is your board assembled with a PIC32MZ2048? Do you have the schematics for this board?
Frank
palcal
Posted: 08:42am 25 Jan 2018
@ Frank,
No, it is a MM+ board I didn't read Graeme's post properly, I do have an MZ2048 Breakout board that I have offered him.
Paul.
isochronic
Posted: 09:14am 25 Jan 2018
I have some smallish pcb's for 100 pin eg the 2048MZ,
"sn-7x", they work ok at 200MHz. Slight difference from extreme pcb.
message for details etc.
Edit - My impression was, the original post listed MZ 2048, On re-reading it
now specifies MM Extreme. (?) which obviously is a different request.
I can offer some MZ2048 pcbs, basically self-powered breakouts with a usb-serial
bridge, not MM specific. Sorry if that is exasperating.Edited by chronic 2018-01-27
OA47
Posted: 11:12pm 25 Jan 2018
My requirements are approx. 60 I/O pins, heap of memory, support for a large monitor and keyboard. So I thought the Micromite Extreme would cover this and if I could find one of Peter's PCB's that would cover it.
  Quote  Edit - My impression was, the original post listed MZ 2048, On re-reading it
Sorry for the confusion Chronic but I was under the impression that the Micromite Extreme uses only the PIC32MZ2048EF chips.
OA47
palcal
Posted: 12:46am 26 Jan 2018
Have you contacted WW yet.
Paul
OA47
Posted: 01:15am 26 Jan 2018
  Quote  Have you contacted WW yet.
I looked on WW's site but couldn't see the PCB's listed. As I am keen to get into this project, I thought I might save some time and hopefully source a board locally. If I can't ,I will have to get one thru WW/BigMik and be patient.
OA47
Azure
Posted: 03:58am 26 Jan 2018
If you PM WhiteWizard he will help you. He has not got them listed on his site yet. I guess they are a little more specialised and low volume for the work he has to do to get them on his site and then take queries about them.
I ordered one of his MM eXtreme 100 type 1 (Black PCB) and MM eXtreme 144 boards by MatherP and they arrived in a very reasonable time. I don't recall if he has any faster (higher priced) shipping options.
isochronic
Posted: 04:30am 26 Jan 2018
  Quote  My impression was, the original post listed MZ 2048, On re-reading it
Why bother.
