Local Time 21:40 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CANBUS CRC etc
retepsnikrep
Posted: 07:40pm 14 Jan 2018
I'm working on a microcontroller project that might eventually get transferred to a micromite but I am struggling to understand a CANBUS crc and security type code formulae.
I sampled some repeating CANBUS data from a working system.
I'm wondering how the two bytes at the end of the packet are generated.
I assume the last is a CRC and the penultimate one some sort of security check as it may not be data related.
Any leads would be appreciated. Sadly polynomials is not my strong point.
ID,D1,D2,D3,D4,D5,D6,D7,D8
203,0,0,0,0,0,0,0,9A
203,0,0,0,0,0,0,20,2F
203,0,0,0,0,0,0,1D,7E
203,0,0,0,0,0,0,0,8B
203,0,0,0,0,0,0,20,10
203,0,0,0,0,0,0,1D,6F
203,0,0,0,0,0,0,0,B8
203,0,0,0,0,0,0,1D,50
203,0,0,0,0,0,0,0,A9
203,0,0,0,0,0,0,20,3E
203,0,0,0,0,0,0,1D,41
and a bit more with some data.
203,24,62,46,24,72,47,20,3C
203,24,92,46,24,72,47,2B,4D
203,24,A2,4B,0,0,0,0,99
203,24,62,46,24,72,46,20,2E
203,24,92,46,24,72,46,2B,7B
203,24,92,4D,0,0,0,0,89
203,24,42,44,24,72,44,20,15
203,24,92,44,24,72,4A,2B,6A
203,24,C2,4C,0,0,0,0,B4
203,24,22,42,24,62,3F,20,1
203,24,92,42,24,62,4F,2B,59
203,25,32,4B,0,0,0,0,AE
Gen1 Honda Insights.
Posted: 10:04pm 14 Jan 2018
Hello Peter.
I have had this link for some time in my favourites: https://www.can-cia.org/can-knowledge/can/crc/
Is the data above raw (i.e. direct readings from CANHI/CANLO) or off an interface IC e.g. mcp2551?
The reason I ask is as far as I understand, the CAN data doesn't fit neatly into bytes (11 bit IDs, 29bit frames etc.) I could very easily be wrong here though. https://en.wikipedia.org/wiki/CAN_bus#Data_frame Edited by CaptainBoing 2018-01-16
retepsnikrep
Posted: 07:18am 15 Jan 2018
Its from an interface and can analyser.
Posted: 09:24am 15 Jan 2018
OK, so it is possible that pre-processing has been done. TBH I am out of my depth with CAN having never pursued any research. It was something that I wanted to play with (not for automotive, RFID readers in airports) but for my needs there are better ways.
I have a mcp2551 break-out board which I've had for years - you can have it if you want to play at a raw level - which might eliminate any fiddling done by the analyser(?) No charge, just PM me with an address and I'll pop it in the post if you interested.
Beyond that I can't really help. my CAN aspirations got sidelined and I have never needed to pick up on them.
hEdited by CaptainBoing 2018-01-16
Boppa
Posted: 10:25am 15 Jan 2018
It would be interesting to see if a canbus adapter for trailers could be done with a micromite, I have been having issues with a trailer plug that has a nice little disco effect on led trailer lights with the dealer supplied adapter, one apparent cure is to fit a ford canbus adapter to it instead, but the adapter costs approximately the same price as 3 of the box trailers its being plugged into! (over $1400 from ford!)
retepsnikrep
Posted: 08:45pm 16 Jan 2018
Ok a slightly different problem.
The canbus sends me the following hex data from a battery management system.
Just to summarise the 12 bit hex voltage data obtained from the 10 cell HCH Lithium BMS. I have grouped it as required. The test voltages I used are not 100% accurate but should be pretty near the number quoted below. e.g. 4v quoted could be 3.95 or 4.05 etc etc
4v per cell
9DD,9E2,9DF,9E2
9E4,9E3,9E5,9E7
9F0,9EA
3v per cell
756,75C,75A,75C
75C,75E,760,761
76B,764,
2v per cell
4D2,4D2,4D2,4D4
4D7,4D2,4D4,4D3
4D7,4D6
1v per cell
246 246 247 246
249 246 247 246
249 24D
0V = 0v per cell (Some leakage and noise here)
0D0,0D4,0C1,0E2
0DE,0E6,0FC,0E3
0C5,0E7
So the question.. How do we get the cell voltage from the above hex data?
Formulae..Edited by retepsnikrep 2018-01-18
Posted: 05:46pm 18 Jan 2018
as an aside, this just dropped in my mailbox:
https://www.microchipdirect.com/product/search/all/APGDT002?mkt_tok=eyJpIjoiWkRKaVl6UmxNRGRsWkROayIsInQiOiJQWmNXVys4alZH R2R6ZkZtbzB1RHpGSTczV2c2MVhpQnFvRklUWkVheDNHVVlIa0RNNkhyeDdPSE4wODRVM1phRW5PY0hkeFdZOXlSS0IwcGxpdGZJcm5YdDE1RndHT0FyNG1Q NDFQWjU4RjhMMnN6RWlSK0MwMEtUQ056WFhQbyJ9
Posted: 07:45pm 18 Jan 2018
Ouch - that's expensive!
You could use a very cheap Arduino.
Or any of a few cheap alternatives. Heck, an elm327 would do at a pinch.
In terms of formulae, others have often been there so if you hunt on the net may find help for whatever the mystery source is.
JohnEdited by JohnS 2018-01-20
