Local Time 21:41 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Line Length
Chopperp
Posted: 06:18am 12 Jan 2018
Hi all,
First post. Long time lurker.
Jim's MMEdit in the Reports gives lines longer than 80 characters if they exist. I was wondering if these longer lines actually use more memory than if they were split. Mainly concerned with a CMM. I do use the "Crunch" feature
Chopperp
ChopperP
Posted: 06:33am 12 Jan 2018
Welcome to the forum.
A line longer than 80 characters is only a problem when you try and use the built-in editor.
MMBasic can handle lines up to 255 characters.
I doubt is there is much difference in performance or memory usage comparing long lines to shorter ones.
Apart from removing leading and trailing white space and comments, 'crunch' does nothing to line length.
Edited by TassyJim 2018-01-13
Chopperp
Posted: 07:00am 12 Jan 2018
Hi Jim
Thanks for that. I remember now something about the 255 characters.
Crunch is great!!!
Chopperp
ChopperP
