Local Time 10:07 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Electronic heater plate....
     Page 1 of 4
Posted: 02:15am 07 Jan 2018
Hello all.
I have a 3mm aluminium plate here that is used for egg incubation. It works, but the temperature regulation is not really what I want, so I am going to change the design.
The current design simply has six 1-ohm 10W wire-wound resistors connected in series, and clamped to the underside of the plate with some heatsink goo. I was thinking more along the lines of four or six TO220 transistors set so they do nothing but heat up, and then bolting those to the underside of the plate.
There is an NTC coupled to the plate, and once it gets up to a certain programmable heat, the current is switched off. This circuit cycles around keeping the plate at the same temperature give or take a degree or two. The plate and eggs are all inside an insulated container, and the lid is not really lifted at all, so as not to let the heat out. Only to retrieve the eggs.
As I am doing some MOSFET research and read that they are a voltage-controlled device, I am thinking perhaps a few MOSFET's would be ideal here. Taking an N-MOSFET such as an IRF540 as a starter, if the gate is 0v, the S-D path will be off(well, very high resistance), and if the gate voltage is 3-4v(gate threshold voltage), the S-D path will be on(start to conduct), but the device will dissipate heat. 10v or so on the gate, according to the datasheet, will switch the device fully on with a very low S-D resistance.
Reading about MOSFETS, the key thing seems to be to switch them as fast as you can from one state to the other, as even in the fully ON state, they dissipate very little heat - which would be right looking at the S-D on resistance of just about any datasheet I pick up.
The same MOSFET info tells me that if you have a gate voltage less then the fully on gate voltage, but still higher then the gate threshold voltage, the device acts like a resistor and will dissipate heat - perhaps a great deal of heat if you are not careful, and if not controlled, you will cook the MOSFET depending on what current can flow in the S-D path.
OK. All that makes sense to me. Now, if I was to use a MM I/O pin to drive the gate with 3.3v or so, this would force the transistor into a state where it would actually dissipate heat, which is what I want.
Now, there would need to be some current-limited testing involved here, but I was thinking four or six(or maybe eight?) MOSFETS, all in parallel, and centred evenly around the aluminium plate so they would all heat up the plate, and share some of that load. Another MOSFET could be used to switch all those on and off if I understand things correctly. There would most likely be a better choice of MOSFET. The IRF540 datasheet is just the first TO220 one I came across.
This is probably where someone will say that bipolar transistors would be a better choice here, having just got me interested in MOSFET's and talked me out of bipolars in the other thread.......
Something else I am also considering is a Peltier-effect device, and putting the plate on the hot side, and a cold-sink on the other side in a standard arrangement for those, and they are very easy to find on eBay or Aliexpress.(unknown quality, but I could try some and see)
All thoughts and comments welcome at this point.
palcal
Posted: 02:20am 07 Jan 2018
I have a couple of Peltier devices, they seem very reiable and easy to use but draw a bit of juice.
Mine are 12v. 4amps.
Paul.
Posted: 02:25am 07 Jan 2018
Juice does not REALLY worry me. The current resistor design draws a few amps when it is "ON". I just had a quick look on eBay, and you can get five Peltier effect devices for about US$14, and if I used four of those centered on the plate perhaps?
The only REAL problem I have with Peltier's is that in this case, you have to find a way to get rid of the cold with a cold-sink.
However, I am thinking if I used a 5mm thick plate for the cold-sink, and a 3mm plate for the heat sink, with the hot-side up, the heat from the hot side would help to warm the cold-sink and keep it from getting frosty?
Never played with Peltier's either. Perhaps I should get some just to play with!
Azure
Posted: 02:27am 07 Jan 2018
I support the Peltier vote. That is what they are made for (heating/cooling/controlling humidity). Cheap unit in different sizes available on ebay.
Azure
Posted: 02:30am 07 Jan 2018
Fan on cold side (with temp sensing control) could be used to stop it frosting and push cold away by keeping ambient air temp flowing past it.
My wine fridges use peltiers mounted inside the sides to control internal humidity. Do not have access to them so cannot see how they are mounted.Edited by Azure 2018-01-08
Posted: 02:43am 07 Jan 2018
I would use one or more of those "gold" metal clad resistors that can be bolted direct onto your plate.
These can then be switched on or off with a mosfet.
Any one of the switched mode power supply control chips could pwm those mosfets directly. And the error amplifier in the controller connected to a temperature sensor.
The pwm switching frequency need not be high, 100 Hz switching rate would be fine for something like this. Edited by Warpspeed 2018-01-08
George65
Posted: 03:21am 07 Jan 2018
Peltiers are fun and simple.
You really want a fan on the cold side in this case so the cold is removed and the things just don't ice up which will limit heating performance.
2 days ago I was going round to the relos to water the garden etc while they are away and saw the house that just sold down the road with a pile of stuff out the front.
I spoted a Waeco car fridge which I picked up on the way back.
The thing is in perfect condition, looks hardly used and had all the cords. It uses a peltier and the thing works a treat. Sitting out the back now in 40o+ heat it's still keeping the cans I put in it under 5o.
It says it will cool to 30 below ambient but it's doing way better than that.
I have another cheaper car fridge of the same type, the little fan on that died about 10 years ago and I couldn't find one the same size. I hacked a bigger hole in the housing and put in a larger computer fan. the thing works WAY better now than it did before.
Moving the heat or cold from the opposite side of these thing makes a real big difference to their efficiency and effectiveness.
Posted: 03:59am 07 Jan 2018
I'm now looking at these things on eBay - ceramic heater elements. Perhaps these could be a good solution? 12v operation, cheap, hot only, no cold-sink required. Anyone used or played with these things?
Posted: 04:08am 07 Jan 2018
They are a good solution where there is a fan, and you don't want the heating element to burn out if the fan fails. Unless your aluminium plate goes above 80 Celsius they will just act like a normal resistor of the specified power.
If your eggs ever get to 80C, they are not likely to hatch.....!
So I cannot see the point really.
A simple basic resistor would work just as well as a heater as anything else.
Bonding the resistor to the metal plate is the only complication, and those gold resistors solve that problem very simply.
Posted: 04:24am 07 Jan 2018
Those gold resistors are expensive . NZ$4 and up each PLUS another $2 for freight for each one! I would need four or five(or more) to get even heat distribution. Using just one(or two) would be pointless, as you would end up with hot-spots where the resistors are, and the rest of the plate gets cold - this is the problem I have now with the resistors clamped to the plate. So I would need to use 6-8(maybe ten) of those gold resistors, and that is starting to get rather expensive compared to other options. You're looking at $40 or so just for the gold resistors, plus another $20 in freight - we're up to sixty bucks just for the resistors so far.
I will have another search on those. Perhaps I was unlucky to strike expensive ones or something, but the other choices just below that listing show similar ratings, and similar prices too!
EDIT: OK, this is interesting. HIGHER power ones are cheaper! I found these when I searched for '50W resistor' - fully expecting them to be almost twice the price of the 30W ones. Weather they are any good is another thing, but perhaps......Edited by Grogster 2018-01-08
Posted: 04:34am 07 Jan 2018
You want cheap even heat, use a much thicker aluminium plate, or use a single resistor to heat up a suitably shaped water storage tank in the base of your incubator.
This could probably be some plastic "Tupperware thing" as the temperature is not going to be high.Edited by Warpspeed 2018-01-08
Posted: 04:44am 07 Jan 2018
If you can scrounge one of those huge heatsinks used on most grid tie inverters, mount that fins up, with a single metal clad resistor bolted underneath.
Eggs on top.... Job done.
Posted: 04:50am 07 Jan 2018
Look for 'heater cartridge' on ebay. They are cheap and work very well.
They are used in 3d printers to control the temperature of the nozzle.
Azure
Posted: 05:10am 07 Jan 2018
Just to throw more options into the mix, there is always the good old heater elements, you get those convection hotplates very cheap these days, maybe not cheap enough for what you are thinking of.
Posted: 05:15am 07 Jan 2018
Owwwwwwwwwwwww!!! Check this thing out!!!
Full size heating pad, complete with NTC sensor. This is the current front-runner.
Posted: 05:24am 07 Jan 2018
I have a few of those pads and they work good although i have the 220v ones.
The higher the voltage the more wire the less current -> better distribution of heat.
A 12v one would need about 12A current. A 220v version not even 1A.
Posted: 05:40am 07 Jan 2018
There is a 24v version for about three bucks extra, and that would probably be the one I would go for, as I need this thing to be portable. A couple of 12v gell-cell batteries in series would supply the 24v, and 6A or so is managable when it not 100% duty cycle. A switchmode PSU can be built-in to charge the batteries as well as supply it when cold for initial heat-up.
Thanks MB - I had never considered 3D printing parts before you mentioned 'Cartridge heater'.....
Posted: 06:53am 07 Jan 2018
That certainly looks like a very nice solution.
Well done !
palcal
Posted: 07:21am 07 Jan 2018
What are you using for a thermostat. These are my favourite thermostat
Paul.
Posted: 07:24am 07 Jan 2018
The pad has an inbuilt NTC thermistor, and you use THAT to regulate the plate temperature, by reading it with a MM or other MCU.
     Page 1 of 4
