Local Time 21:40 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Inverter Software on rPi
Phil23
Posted: 08:28pm 05 Jan 2018
Just wondering if anyone here can tell me if this software will run on a rPi.
Posted this in the Solar forum, but no response yet.
Even better, but a big ask is if someone could confirm it will at least load.
  Phil23 said   From the manual , which seems common over several inverter brands
Giantpower, in this instance:-
[Quote] Platforms supported by software are listed below:
Ø Windows 2003/XP/Vista/2008 (32bit &x64bit)
Ø Windows 7/8 (32bit& x64bit)
Ø RedHat Linux 8,9
Ø Linux RedHat Enterprise AS3, AS5, AS6(32bit &64bit)
Ø Linux SUSE 10 (32bit &64bit)
Ø Linux Cent OS 5.4 (32bit &64bit)
Ø Ubuntu 8.x,9.x,10.x (32bit &64bit)
Ø Linux Fedora 5
Ø Linux OpenSUSE 11.2 (32bit &64bit)
Ø Linux Debian 5.x, 6.x (32bit &64bit)
Ø Mac OS 10.6(x64bit)
Ø Mac OS 10.7(x64bit)
Ø Mac OS 10.8(x64bit)[/quote]
The Version I received does not have a windows installer & the manual states it's a portable app & just needs dropping in a directory to run.
That all works out fine on Windows.
On the Ubuntu box, same seemed to apply, download the archive, dig out the software folder from a few levels down, then just run the executable.
I get the impression that there my be a different launch procedure required on an rPi.
I'm no Linux Guru by any measure, more a case of running it with training wheels.
Phil.
Edit,
Another link to a different vendor.
Phil
Edit:-
I see there are different OS's here and should of mentioned mine (3) is running the default Raspian install from NoobsEdited by Phil23 2018-01-07
Posted: 10:36pm 05 Jan 2018
A bit odd... the link in the other forum is to a Windows executable and nothing else - so no.
Yet there is mention of a manual that lists various Linux versions.
Provide more info / URLs?
Or use some open source (MPPT?) software and be done with the hassle of proprietary (is it?)?
Phil23
Posted: 08:16pm 06 Jan 2018
  JohnS said   A bit odd... the link in the other forum is to a Windows executable and nothing else - so no.
Opps,
Wrong thing in the clipboard when I posed the link.
The other thread is just over on the Solar Forum here.
The link the manufacturers provided for software etc is this.
Just a directory listing to download from.
Has both 32 & 64 bit Linux version, which I did manage to fire up on a Ubuntu box I have, but following a similar process didn't work on the rPi.
That's where I'm wondering if I need a different distribution, but don't know enough of the Linux world to go any further.
Have also notices that there is a Ubuntu Dist for the Pi too.
Phil
Posted: 09:42pm 06 Jan 2018
You will probably have to compile for the source to run it on a RPi
I expect all the precompiled ones are for x86, not ARM processors
Posted: 03:59pm 07 Jan 2018
Opps,
Phil
I think the link is here
And looks x86 so would at least need a recompile.
JohnEdited by JohnS 2018-01-09
Phil23
Posted: 08:01pm 07 Jan 2018
  TassyJim said   You will probably have to compile for the source to run it on a RPi
Thanks Jim & John,
That's probably what I should have asked, whether a different compile was required for rPi.
Partially had things like CumulusMX in my head that run on multiple platforms.
Completely different beast though.
Phil.
