Local Time 09:15 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi-cromite: IOT with ThingSpeak
Posted: 01:44pm 30 Nov 2017
This example shows how to log data to Thingspeak with the Pi-cromite. It uses the Pi-cromite's TCP client capability. The code measures the temperature every 30 seconds and then uploads the current temperature and the running maximum and minimum to Thingspeak. I was surprised how easy this was
option explicit
option default none
Dim m$,s$, n$, api_key$="my Write API Key"
Dim float current,maxtemp=-1000.0,mintemp=1000.0
m$="GET http://api.thingspeak.com/update?api_key="+api_key$+"&field1="
TCP client "184.106.153.149",80 'fixed address for Thingspeak HTTP
current=DS18B20(33)
If current>maxtemp Then maxtemp=current
If current<mintemp Then mintemp=current
s$=m$+Str$(current)+"&field2="+Str$(maxtemp)+"&field3="+Str$(mintemp)
s$=s$+Chr$(13)+Chr$(10)
Print s$;
TCP send s$
Pause 1000
TCP receive n$ 'clear the TCP receive buffer
TCP close
Pause 29000
Loop
You can see the cold UK temperature here
Edited by matherp 2017-12-02
kg4pid
Posted: 05:41pm 30 Nov 2017
I'm trying to follow your code but I don't see where you provide a login/user name along with a password. In looking at the web page I see a 'channel id'. Why do I not see this in the code?
While it looks simple, there must more code/setting that are somewhere else.
MaxEdited by kg4pid 2017-12-02
Phil23
Posted: 08:41pm 30 Nov 2017
It's probably in the first line below,
api_key$=
Uses an api key instead of username/pwd by the look of it.
Edited by Phil23 2017-12-02
Posted: 08:29am 01 Dec 2017
  Quote  While it looks simple, there must more code/setting that are somewhere else.
There isn't otherwise I would have included it.
The Write API Key is the username/password and channel id combined on ThingSpeak which is why I didn't include my key
Azure
Posted: 09:57am 01 Dec 2017
I thought you were going to share
