Local Time 09:15 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Com Port Problems
     Page 1 of 5
lew247
Posted: 01:40pm 27 Nov 2017
I'm stuck with a com port problem
On COM1 I have data coming in from the outdoor weather board into the Explore 100 Module
On COM2 I have an ESP8266 module parsing weather from openweathermap
COM 1 is working perfectly and I have no problems with it
COM2 is not working
Sometimes it shows data, sometimes it doesn't, it just doesnt make sense to me
The OUTPUT from the ESP8266 module is this - which is exactly what I want it to do
[quote]Today,shower rain,09d[/quote]
The output, is day, description and weather icon for the day
The idea is this
Com2 the output from the ESP8266 will have 4 sets of weather being transmitted, today, tomorrow, day after and day after that
The program sorts it by the 1st section received on the COM2 port
Today - goes to SUB T1 which parses the data for today and displays it
Tomorrow - goes to the SUB T2 which parses the data for tomorrow and displays it
Day2 - goes to the SUB T3 which parses the data for that day and displays it
DAY 3 - goes to the SUB T4 which parses the data for that day and displays it
For the moment I'm only interested in getting the data from COM2 and parsing todays data and displaying it in the SUB T1
Here is the relevant code - for some reason the COM2 section will not work properly
I have tried to make COM2 work similar to COM1 but couldn't get it working/
[code]
Open "COM1:19200,1024,isr" As #1 'Open port for HC-12 TX/RX
OPEN "COM2:9600, 1024" AS #2 'Open port for ESP8266
'*************Main program section************
DO
If head<>tail Then ' collect sentence from buffer
B$ = CB$(tail)
tail = (tail Mod 10)+1
EndIf
if B$<>"" THEN SERIAL1 ' if data GOSUB Serial1
B$ = ""
END IF
IF LOC(#2) > 0 THEN SERIAL2 'If data in Com1 then GOSUB Serial2
LOOP
'************END PROGRAM*******************
Sub isr ' serial port handler
Local I, S$ length 80
S$ = Input$(72,#1) ' grab data into temporary buffer
Z$ = Right$(Z$,255-Len(S$))+S$ ' add to end of linear buffer
I = Instr(Z$,Chr$(13)+Chr$(10)) ' check for eol marker (CR+LF)
If I<>0 Then
CB$(head) = Left$(Z$,I-1) ' transfer into circular buffer
head = (head Mod 10)+1
If I<254 Then Z$ = Mid$(Z$,I+2) Else Z$=""
EndIf
End Sub
SUB SERIAL1
N = GetFieldArray(B$)
IF Left$(B$,4) = "STXG" THEN PRINT "Searching for gps lock"
IF Left$(B$,4) = "STXT" THEN TIME1
IF Left$(B$,4) = "STXW" THEN WEATHER
END SUB
SUB WEATHER
LOCAL N as INTEGER
ctrlval(5)=STR$(humidity,0,1) 'Humidity indoor
ctrlval(6)=STR$(VAL(FieldArray$(14)),0,1) 'Humidity outdoor
ctrlval(2)=STR$(temp,0,1) 'temp indoor
ctrlval(3)=STR$(VAL(FieldArray$(1)),0,1) 'temp outdoor
ctrlval(8)=STR$(VAL(FieldArray$(11)),0,2) 'min temp
ctrlval(9)=STR$(VAL(FieldArray$(9)),0,2) 'max temp
ctrlval(11)=STR$(VAL(FieldArray$(13)),0,2) 'voltage
ctrlval(13)=STR$(VAL(FieldArray$(4)),0,1) 'speed
ctrlval(15)=STR$(VAL(FieldArray$(5)),0,1) 'gust
ctrlval(17)=FieldArray$(7) 'rain
ctrlval(20)=FieldArray$(2) 'pressure
Heading=VAL(FieldArray$(3)) 'Wind Direction
drawpointer(heading) 'draw the pointer
END SUB
SUB SERIAL2 'Com2 ESP8266 Weather Forecast
LOCAL N as INTEGER
N = GetFieldArray(D$)
IF FieldArray$(0) = "Today" THEN T1 'If the 1st array is "Today" then GOSUB T1
IF FieldArray$(0) = "Day2" THEN T2 'If the 1st array is "Day2" then GOSUB T2 'If the 1st array is "Day2" then GOSUB T2
IF FieldArray$(0) = "Day3" THEN T3 'If the 1st array is "Day3" then GOSUB T3
IF FieldArray$(0) = "Day4" THEN T4 'If the 1st array is "Day4" then GOSUB T4
End Sub
SUB T1 'T1 Today
desc0$ = FieldArray$(1)
ICON$ = FieldArray$(2)
Select Case ICON$ 'To Display the CORRECT weather icon for today
Case "01d"
ICON$ = ICON$ + ".ppm"
Case "01n"
Case "02d"
Case "02n"
CASE "03d"
CASE "03n"
Case "04d"
Case "04n"
Case "09d"
CASE "09n"
CASE "10d"
CASE "10n"
CASE "11d"
CASE "11n"
CASE "13d"
CASE "13n"
CASE "50d"
CASE "50n"
Case Else
ICON$ = "50d.ppm"
End Select
print ICON$ " icon printed"
pause 20
DisplayPicture ICON$,280,260 'Weather icon
pause 50
Text 285,310, desc0$ , LM, 2, 1, RGB(BLACK), RGB(WHITE) 'Print the Day of week
pause 100
print "This SHOULD be working"
END SUB
Function GetFieldArray( Record$, Delimiter$, KeepQuotes ) 'Function to get array from COM port
Local Index, Char, InQuote, Count
InQuote = 0
Count = 0
FieldArray$(Count) = ""
If Delimiter$ = "" Then Delimiter$ = ","
For Index = 1 To Len(Record$)
Char = Asc(Mid$(Record$, Index, 1))
If Char = 34 Then InQuote = Not InQuote
If Not InQuote And Instr(Delimiter$, Chr$(char)) >= 1 Then
Count = Count + 1
Else
If Char <> 34 Or KeepQuotes Then
FieldArray$(Count) = FieldArray$(Count) + Chr$(char)
EndIf
EndIf
Next
GetFieldArray = Count + 1
End Function[/code]
Can anyone spot what is wrong, or have suggestions on how to make COM2 work right?
Phil23
Posted: 08:25pm 27 Nov 2017
Don't have an immediate answer, but I'd change it a bit so it doesn't immediately jump into the SERIAL2 sub.
[Code] IF LOC(#2) > 0 THEN SERIAL2 'If data in Com1 then GOSUB Serial2[/code]
Don't know exactly the length of the string coming from the ESP, but you could have an interrupt set to either jump straight into the Sub, or set a flag to say the Sub needs to be processed.
I use this, but I'm looking for 120+ characters in my block of data
[Code] OPEN "COM1:9600,,RecComs,120" AS #1
[/code]
Then this, with the DO loop to make sure the coms is completely received.
[Code]Sub RecComs
Local Integer HdrLoc,FtrLoc,BufLen
Local String HdrFnd
Timer_L=Timer
If LOC(#1)>10 then 'If COM1 serial port buffer is NOT empty.... Was 100
DO WHILE BufLen<> LOC(#1)
BufLen=LOC(#1)
PAUSE 5
LOOP
DataStr=INPUT$(LOC(#1),#1) 'then suck everything in the buffer out and stick it in D$....
[/code]
May not be the most correct approach, but it's working.
Phil.
lew247
Posted: 08:30pm 27 Nov 2017
The length of the string coming from the ESP varies depending which day the weather is for
Posted: 08:44pm 27 Nov 2017
I can't see where you fill D$ with the data coming in on com2
lew247
Posted: 08:54pm 27 Nov 2017
Whoops
I copied one of the older serial2 subs*
[quote]SUB SERIAL2 'Com2 ESP8266 Weather Forecast
Local D$ 'Get the data in arrays
LOCAL N as INTEGER
D$ = Input$(254, #2) 'Suck everything in buffer out
End Sub[/quote]
It still doesn't work
I substituted this for the original and it doesn't print - yet I can see the data on the web page (Yes I am printing to the web page as well as the console on the ESP8266)
[quote]SUB T1
Print "Got here"
END SUB[/quote]
Edited by lew247 2017-11-29
Phil23
Posted: 08:57pm 27 Nov 2017
  lew247 said   The length of the string coming from the ESP varies depending which day the weather is for
So can you take a guess at it's minimum length?
Then set the com interrupt for that & then make sure the buffer has finished filling once you are in the sub?
10 or 20 for a trigger maybe?
Edited by Phil23 2017-11-29
lew247
Posted: 09:00pm 27 Nov 2017
This is the maximum output from the ESP8266 when it sends the data for the forecast
[code]
Day4,Thu Nov 30 11:00:00 2017 ,sky is clear,01d,-1.17,2.8,1014.68,87,4,sky is clear [/code]
I thought I had it set to send all the days in one string, but I have it set to send each day as a seperate output from the ESP
This is the minimum from the ESP8166
[code]Today,rain,09n[/code]Edited by lew247 2017-11-29
Posted: 09:25pm 27 Nov 2017
What happens if you change:
[Quote=Lew]IF FieldArray$(0) = "Today" THEN T1 'If the 1st array is "Today" then GOSUB T1[/Quote]
To:
T1
ENDIF
I have had issues calling SUB's as part of a single-line IF/THEN before in the past - I have no idea why that should be, but when I made them multi-line, with the call to the SUB on a line of it's own, MY problems went away - worth a try.
Also, remember that even using LOC to detect if there is data in the COM2 buffer, you need to allow TIME for that data to arrive. If you have a line like IF LOC(#2)>0 THEN type command, the code will execute as soon as there is a single byte in the buffer - but that won't be all your message, as it has not arrived yet!
This caught me out in my first experiments with COM port buffers.
I use a simple pause, or you can specifiy how many bytes MUST be there before doing anything else, but if the message will vary in length, a simple pause will catch all of it.
DO:LOOP UNTIL LOC(#2) 'Wait for some data to arrive in COM2 buffer
PAUSE 150 'Allow all of message to arrive in buffer
D$=INPUT$(LOC(#2),#2) 'Suck everything available from the buffer
[/Code]Edited by Grogster 2017-11-29
lew247
Posted: 10:00am 28 Nov 2017
I'm really stumped now
I have the com port working but it's NOT printing what's coming in correctly
The input to the com port FROM the ESP8266 is this
[code]Today,few clouds,02d[/code]
This is what's printed on the console when I run the micromite
[quote]This SHOULD be working 1
02d
Today
few clouds
This SHOULD be working 2
[/quote]
The ICON$ "SHOULD" with the following code attach .ppm to the end of the icon number so it can display properly, but it's not.
Also the word "Today" is being pulled from somewhere FieldArray(0) but I'm not asking it to print that and have no idea how it's getting in there
AND D$ is being printed twice also?
This is the relevant code for parsing the input
[code]
SUB T1 'T1 Today
IF ICON$ = "01d" then ICON$ = "01d.ppm"
IF ICON$ = "01n" then ICON$ = "01n.ppm"
IF ICON$ = "02d" then ICON$ = "02d.ppm"
IF ICON$ = "02n" then ICON$ = "02n.ppm"
IF ICON$ = "03d" then ICON$ = "03d.ppm"
IF ICON$ = "03n" then ICON$ = "03n.ppm"
IF ICON$ = "04d" then ICON$ = "04d.ppm"
IF ICON$ = "04n" then ICON$ = "04n.ppm"
IF ICON$ = "09d" then ICON$ = "09d.ppm"
IF ICON$ = "09n" then ICON$ = "09n.ppm"
IF ICON$ = "10d" then ICON$ = "10d.ppm"
IF ICON$ = "10n" then ICON$ = "10n.ppm"
IF ICON$ = "11d" then ICON$ = "11d.ppm"
IF ICON$ = "11n" then ICON$ = "11n.ppm"
IF ICON$ = "13d" then ICON$ = "13d.ppm"
IF ICON$ = "13n" then ICON$ = "13n.ppm"
IF ICON$ = "50d" then ICON$ = "50d.ppm"
IF ICON$ = "50n" then ICON$ = "50n.ppm"
ENDIF
print "This SHOULD be working 1"
pause 20
print D$
print icon$
PRINT desc0$
'DisplayPicture ICON$,280,260 'Weather icon
pause 50
pause 100
print "This SHOULD be working 2"
END SUB[/code]
Posted: 10:12am 28 Nov 2017
Don't know if it is relevant but you have a spurious ENDIF following a lot of single line IF statments
lew247
Posted: 10:21am 28 Nov 2017
Thanks Peter, I thought the "ENDIF" was needed
I removed it but I still get
[code]This SHOULD be working 1
02d
Today
few clouds
[/code]
Which is showing D$ repeated twice
and "Today" printed FieldArray$(0) when it wasn't told to print that
and the ICON$ isn't being appended with ".ppm" it seems to be ignoring the "THEN" part of the statement
The D$ being repeated twice isn't causing a problem, its the PRINT ICON$ which is
lew247
Posted: 10:27am 28 Nov 2017
I changed the print statement so it ONLY prints the ICON
PRINT ICON$ now results in this
[code]02d
Today[/code]
It "should" print 02d.ppm and NOT have a line feed and then Today
lew247
Posted: 10:38am 28 Nov 2017
Changed the SUB so it's the way it's "meant to be" in the manual
[code]SUB T1 'T1 Today
ICON$ = "01d.ppm"
ELSEIF ICON$ = "01n" then
ICON$ = "01n.ppm"
ELSEIF ICON$ = "02d" then
ICON$ = "02d.ppm"
ELSEIF ICON$ = "02n" then
ICON$ = "02n.ppm"
ELSEIF ICON$ = "03d" then
ICON$ = "03d.ppm"
ELSEIF ICON$ = "03n" then
ICON$ = "03n.ppm"
ELSEIF ICON$ = "04d" then
ICON$ = "04d.ppm"
ELSEIF ICON$ = "04n" then
ICON$ = "04n.ppm"
ELSEIF ICON$ = "09d" then
ICON$ = "09d.ppm"
ELSEIF ICON$ = "09n" then
ICON$ = "09n.ppm"
ELSEIF ICON$ = "10d" then
ICON$ = "10d.ppm"
ELSEIF ICON$ = "10n" then
ICON$ = "10n.ppm"
ELSEIF ICON$ = "11d" then
ICON$ = "11d.ppm"
ELSEIF ICON$ = "11n" then
ICON$ = "11n.ppm"
ELSEIF ICON$ = "13d" then
ICON$ = "13d.ppm"
ELSEIF ICON$ = "13n" then
ICON$ = "13n.ppm"
ELSEIF ICON$ = "50d" then
ICON$ = "50d.ppm"
ELSEIF ICON$ = "50n" then
ICON$ = "50n.ppm"
ENDIF
print icon$
Text 285,310, desc0$ , LM, 2, 1, RGB(BLACK), RGB(WHITE) 'Print the weather description
END SUB[/code]
However I still have the same problem the ICON hasn't got .ppm appended to it
and somehow it also prints a line feed and FieldArray$(0) which is "Today"
This is what's printed on the console now
[code]02d
Today[/code]
Full code is attached if anyone wants to check it
2017-11-28_205258_Weather-Display.zip Edited by lew247 2017-11-29
Posted: 11:26am 28 Nov 2017
Hello Lew.
A couple of things jump out to me.
The use of IF...ELSEIF ... will slow your code down - every test has to be performed every time, even if you have made a change to ICON$ earlier on. It was better when you had SELECT ... CASE... as the code will jump to the END SELECT as soon as the associated CASE has completed - the same as if you had a GOTO on the end of every IF/ELSEIF line..
But... I can't see any difference between ICON$ after each test except that it will get ".ppm" added to it, so instead of all the "expensive" IFs or SELECT, why not simply concatenate it at the beginning of T1? ::
SUB T1 'T1 Today
ICON$ = FieldArray$(2)+".ppm"
print icon$
END SUB
Am I missing something? This will be *much* faster, is easier to read and saves a load of program space. This is just a suggestion and in no way intended to be contest - it is technique. If you wanted to do other things with each test then you have to go down the SELECT/CASE route.
Edited by CaptainBoing 2017-11-29
lew247
Posted: 01:56pm 28 Nov 2017
Brilliant idea CaptainBoing - I hadn't thought of doing it like that
The sub works
but
I still get the wrong data
This is the result of Sub TQ
[code]> RUN
04d
Today.ppm
[/code]
I changed T1 to this
print icon$
Print "This is what the com port is receiving - "
PRINT D$
END SUB[/code]
This is the result
It's appending the .ppm like it's meant to BUT to the wrong item, an item it's not meant to get seeing
[code]> RUN
04d
Today.ppm
Today,broken clouds,04d
[/code]
I really can't see Why or How it's printing the data twice
This is the main bit that tells the program to jump to SERIAL2
[code]IF LOC(#2) > 0 THEN SERIAL2 'If data in Com1 then GOSUB Serial2[/code]
This is the sub that gets the data from COM2
[code]SUB SERIAL2 'Com2 ESP8266 Weather Forecast
LOCAL N as INTEGER
END IF
End Sub[/code]
And this is the function for sorting the FieldArray
[code]
'***************************Function to get array from COM port*******************************
InQuote = 0
Count = 0
Count = Count + 1
Else
EndIf
EndIf
Next
End Function
'***********End of this function[/code]
EDIT:
I'm pretty sure FieldArray function is working perfectly because I'm using it on COM1 with no problems to parse the outdoor data
I'm wondering do I need a seperate function for COM2?
Edited by lew247 2017-11-30
Azure
Posted: 01:59pm 28 Nov 2017
I think there might be a problem in your GetFieldArray Function.
Could be why you can't get the latter part to work.
Have you checked if GetFieldArray is processing the string into the FieldArray correctly by doing a test for loop to print each entry created?
PRINT "Test listing of FieldArray$()"
FOR check% = 0 to numentries
PRINT "FieldArray$(" check% "): " FieldArray$(check%)
NEXT
PRINT "Test listing end"
I did not check precendence but it looks like the "if (NOT variable AND test2) then"
in GetFieldArray might need another set of parenthesis "if (NOT variable AND (test2)) then".
might need to be:
If (Not InQuote) And (Instr(Delimiter$, Chr$(char)) >= 1) Then
Edited by Azure 2017-11-30
Posted: 02:35pm 28 Nov 2017
print icon$
PRINT D$
END SUB[/code]
This is the result
[code]> RUN
04d
Today.ppm
[/code]
I agree with Azure above - this is about the data in the Filed Array$. If the word "today" is getting ".ppm" concatenated, that tells me that FieldArray$(2) contains "today".
Can you add the following bit of code to your T1 sub, right after the sub declaration?
[code]
local integer nn
for nn=1 to ?? ' put the size of the array instead of ??
print nn,FieldArray$(nn)
Next
[/code]
and this will show the index number and contents of the array - I am certain it will show that you are either getting the wrong data in the array element or pointing to the wrong element.
If the data is wrong then it points to a problem elsewhere in the code.
Edited by CaptainBoing 2017-11-30
lew247
Posted: 02:44pm 28 Nov 2017
[code]'**************************************Today************************************
SUB T1 'T1 Today
local integer nn
for nn=1 to 3 ' put the size of the array instead of ??
Next
print icon$
PRINT D$
END SUB
'********************************End of Today*************************************************[/code]
This is the result
[quote]
> RUN
1 light intensity shower rain
2 09d
Today
3 light intensity shower rain
09d
Today.ppm
Today,light intensity shower rain,09d
[/quote]
IF I change your modification to
local integer nn
for nn=0 to 2 ' put the size of the array instead of ??
Next
print icon$
PRINT D$
END SUB [/code]
Then I get this result - which is correct there are 3 items, 1 the word Today,2 weather description, and 3 Icon number
[quote]> RUN
0 Today
2 09d
Today
09d
Today.ppm
[/quote]Edited by lew247 2017-11-30
Posted: 02:49pm 28 Nov 2017
so it looks like there is a newline character(s) in the middle of the (2) element data.
change this line
to read
ICON$ = left$(FieldArray$(2),3)+".ppm"
and run then code again and post the results here.
I still think there might be some problem with the populating of FieldArray$()
Posted: 03:08pm 28 Nov 2017
I think the data is getting munged...
you are expecting:
but if you are not lining the data up right, you could easily get to
light intensity shower rain,09d<nl>Today
with the newline and the word "today" a hangover from the previous line and becoming joined to the (2) element of the next reading.
I think it is all down to how the data is coming in from the port. I will take a look at it in a little while (have to do some work )
     Page 1 of 5
