Local Time 09:15 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2 & MM+ ColorDepth for LCD screens
erbp
Posted: 04:31am 27 Nov 2017
Does anyone know if there is a list / chart anywhere that shows the color depths used by the various LCD screen drivers available either in-built in MM firmware or as a loadable C Sub?
I am particularly interested in knowing this information for the following common screens:
2.4" and 2.8" ILI9341 TFT LCDs
4" ILI9481 IPS LCD (using Peter Mather's loadable driver)
4.3", 5" and 7" SSD1963 TFT LCDs
Color Depth could be specified as either total colors supported, color depth in bits or the RGB code used by the interface - e.g. 65K colors = 16 bit color depth = RGB565 coding.
Thanks,
Phil.
Posted: 09:03am 27 Nov 2017
The hardware COMMUNICATION to all displays is RGB565 except the SSD1963 which is RGB888. However, the colour depth the individual TFTs are capable of resolving may be much less.Edited by matherp 2017-11-28
erbp
Posted: 11:24am 27 Nov 2017
Thanks Peter.
Cheers,
Phil.
