Local Time 22:29 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question to Picromite
Frank N. Furter
Posted: 09:36am 22 Nov 2017
Hi!
Can anybody help me? I can't leave the Picromite environment when I started it from console! CTRL-Z (or CTRL-Y - it's a german keyboard) doesn't work!
CTRL-Z only works if I run ./mmbasic in a console under the graphical window (startx)!?
Is there a way to use the whole monitor with Picromite (all text is in a relative small window on my screen...)
Thanks!
Frank
...Does anyone know what happened to the forum in the last few days? I have only been seeing new messages since today and can post something, the forum was closed for me since november 13th and only messages until the 13th were visible. How can it be that countless new messages have been written since then??
Posted: 10:06am 22 Nov 2017
Text size is easy
I don't know why ctrl-Z isn't working when logged in from a non-windowed console. I do everything headless over SSH so this isn't something I ever use. I'll post a question on the Pi forum but it isn't usually very helpful
panky
Posted: 10:21am 22 Nov 2017
@Frank,
I have had continuous access to the forum over the last 10 days with new messages, posts from myself and others appearing every day. Sounds like it may be your ISP with the issue.
Cheers,
panky.
Frank N. Furter
Posted: 11:29am 22 Nov 2017
@Matherp: Thanks for your effort! I think the textsize is not really the problem - I can use only a little bit more then a quarter of the screen for text! The usable size is as big as the unscaled window under startx... - the rest of the screen remains black but is usable with graphic commands...
I use my Pi's always with keyboard, mouse and monitor...
@Panky: When I logged in, I got the message that I can't write any messages because the forum is being maintained or because a storm is coming... ???!!!
What did you mean with "ISP"?
Frank
twofingers
Posted: 11:50am 22 Nov 2017
  Frank N. Furter said   @Panky: When I logged in, I got the message that I can't write any messages because the forum is being maintained or because a storm is coming... ???!!!
Frank
Hi Frank,
I can't anything say to the Picromite issue.
ISP = Internet Service Provider.
I didn't have any problems to read and write to to TBS in the last days.
Michael
The lone and ...
Frank N. Furter
Posted: 06:34pm 22 Nov 2017
Hi Michael,
this is very strange!!! I tried it from two different locations with two different computers and two different providers...
Frank
Frank N. Furter
Posted: 07:13pm 23 Nov 2017
it seems I'm the only one using the Picromite with a HDMI monitor...
Now I can use about 2/3 of my HD monitor (1920 × 1080) with:
"option display 60,132"
@Peter: Is it possible to increase the second value to about 200??? - this would be enough to use the complete monitor for text!
CTRL-Z works when I started NANO before (then I can leave NANO and MMBasic with CTRL+Z)! Then I get my "pi@raspberrypi:~/mmbasic $" but when I try "sudo reboot" or "sudo halt" I get "plymouth-reboot.service" or "plymouth-halt.service" and the system hangs...
Frank
