Local Time 09:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E28 console
BrianP
Posted: 01:06am 22 Nov 2017
This is probably one for Grogs or Rob - can I still use the console pins on the 'Mite or does the 1455 connection get in the way of this. I suspect I might already know the answer...
If I "have" to use the serial console connection then might I have to remove the 1455 chip, or is there an easier way to enable serial console functionality?
I have an application already developed that really requires the serial console connection for remote control of the E28.
(Would be really nice if either USB or console could have been used at will.)
Brian P.
Posted: 01:46am 22 Nov 2017
YES, you can do this, but you need to overcome the 1k5 series resistor between TxD on the 1455 and RxD on the MX170. this means that your external serial device needs to be able to sink AND source at least 3mA. the 1k5 series resistors between 1455 and MX170 were specifically included in the design to allow for this sort of application.
see the below schematic:
2017-11-22_104341_E-28_1C_diagram.pdf
rob :-)
BrianP
Posted: 01:50am 22 Nov 2017
Rob - thanks so much - just what I wanted to hear
Brian P.
BrianP
Posted: 02:03am 22 Nov 2017
One last question (I hope) - I see from the schematic that the 1455 is also connected to the 'Mite pins 4 & 5. If I am using pins 2-7 & 9 for a keypad, does this have any unforeseen ramifications? It seems to work fine.
Ta
Brian P.
Posted: 02:54am 22 Nov 2017
when not in programming mode, the 1455 tristates the connection to pins 4 and 5 of the MX170, so should, in theory, have no (or at least negligible) effect on the function of the pins.
rob :-)
Edited by robert.rozee 2017-11-23
BrianP
Posted: 03:41am 22 Nov 2017
Ta muchly
B
Phil23
Posted: 08:27pm 22 Nov 2017
  robert.rozee said  this means that your external serial device needs to be able to sink AND source at least 3mA.
Rob,
Can you answer of the top of your head whether most of the commonly used modules are capable of this?
Thinking ESP-01's etc for WiFi.
as well as HC-05 & HC-06 for Bluetooth,
HC-11 & HC-12 for 433MHz applications.
Phil.
Posted: 11:22pm 22 Nov 2017
you would have to try each one and see, i suspect that many may have 1k series resistors that would cause a problem. your best bet is to just place a buffer in front of pin 12. for example a 74LVC1G34 (single buffer in an SMD package), or i believe an LM555 can also be wired up as a buffer/driver.
rob :-)
Quazee137
Posted: 10:49am 23 Nov 2017
Here is a few other options like Rob's
dual Optocoupler
SN74LVC2G17 Dual Schmitt-Trigger Buffer
SN74LVC2G241
Quazee137Edited by Quazee137 2017-11-24
