Local Time 09:05 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USB Host Implimentation
panky
Posted: 07:44pm 09 Nov 2017
Several boards for the Micromites have the physical Host USB interface included on board. Can anyone advise whether there are working examples of using these or, perhaps Geoff or Peter, are there plans to impliment Host USB functionality into MMBasic at some stage?
Thanks,
Doug.
Posted: 11:41pm 09 Nov 2017
I posted a similar question a few months back and drew a blank. Host would be lovely wouldn't it? a world of USB drives, keyboards, mice etc just opens up!
In the meantime I use these for my USB keyboard interfaces where I can't get around it... bit "terminal-y" but it works fineEdited by CaptainBoing 2017-11-11
Posted: 11:44pm 09 Nov 2017
  Quote  a world of USB drives, keyboards, mice etc just opens up!
And this is the problem. Each one needs coding individually (lots of coding) and in the case of the three mentioned all are already supported in different tech (PS2 mouse only on MMX), PS2 keyboard, SDcard
panky
Posted: 01:05am 10 Nov 2017
I understand Peter, my question was related to a idea to implement some sort of printer interface. As there are USB to Centronics adapters and I have an old Epson Centronics printer, I thought I may be able to some simple Esc2P codes out to the printer via USB.
Would it be feasible to have even basic (no pun intended 😀 ) usb enumeration and leave the actual "drivers" to be done as c functions. Please excuse me if I seem to making this appear simplistic - just curious as to why they are included on your boards and if you had something in mind.
Doug.
Posted: 04:05am 10 Nov 2017
I have a long term plan to support USB keyboards but that is as far as it goes. As Peter said, there are too many devices to support generally.
Posted: 05:57am 10 Nov 2017
USB CDC and HID host would allow lots of things to be connected.
I have played with that before and it is not as easy as i hoped for.
It basically is a serial interface but with lots of overhead and structure. This allows automatic recognition, loading of drivers etc. If you just want to do simple stuff you will also need to do the complicated stuff unfortunately.
A PC has lots of capacity to do all that complicated stuff.
A microcontroller with USB host could be done but then you need to narrow it done to a few specific devices, otherwise it gets out of hand very quickly.
A keyboard/mouse would be great, then again with a touchscreen lots of that can be done anyway.
Posted: 04:24pm 10 Nov 2017
I will go so far as to say that USB printer support will NEVER happen. Forgetting the very valid point about their being so many different ones for the moment, USB printers are controlled from within a driver, and there is no way to install said driver under a Micromite - to say nothing of how hard that would be to code anyway.
Having said that, there are plenty of serial thermal printers available you can easily interface to the MM/MM+/MMX. Have a look at this thread where I hook up a $50 thermal printer to a MM.
CircuitGizmoes hooked up a parallel printer interface to drive a dot-matrix printer for basic text output using the PORT command and an I/O pin to pulse for the STROBE line. Dot-matrix is probably a bit too retro though.
Posted: 02:19am 11 Nov 2017
  Grogster said   Dot-matrix is probably a bit too retro though.
HERESY!!!
kg4pid
Posted: 04:53am 11 Nov 2017
Bussiness still use dot matrix whenever a multi-part form is printed, so they are still around, but in declining numbers. I still use one because it is cheaper to use than laser, inkjet or thermal. I'm cheap, what can I say.
Max
