Local Time 23:53 11 Nov 2026 Privacy Policy
Forum Index : EV's : garden tractor
jorn
Posted: 10:37am 17 Jan 2024
Based on a John Deere type, I wanted to make a usable electric garden tractor.
Started with the flanges of the rear wheels.
jorn
Posted: 11:29am 17 Jan 2024
Shaping the axles.
jorn
Posted: 11:05am 18 Jan 2024
The scale is approximately 1:5 so that the tractor can really be used for work in the garden.
jorn
Posted: 12:37pm 18 Jan 2024
A set up with a 36 volt motor.
Edited 2024-01-19 06:57 by jorn
jorn
Posted: 10:21am 19 Jan 2024
For a smaller turning circle I made a narrowfront-axle.
jorn
Posted: 11:40am 20 Jan 2024
In my tractor model actually fits a water-cooled 4-cylinder engine. That's why I thought about a 4 cyl. solenoid.
I started with a 1 cylinder test setup.
Edited 2024-01-20 21:43 by jorn
Revlac
Posted: 12:15am 21 Jan 2024
Nice work,  solenoids do work and the timing could be from the crankshaft etc, but how are you going to limit the power to them, PWM speed comptroller or something better?
Ah found it, you used an electric wheel barrow motor instead.
Edited 2024-01-22 12:21 by Revlac
Cheers Aaron
Off The Grid
jorn
Posted: 10:05am 22 Jan 2024
The shaping of a four-cylinder solenoid engine for my tractor is an ongoing project with test setups.
jorn
Posted: 10:33am 22 Jan 2024
Later I mounted on the rear wheels of my tractor  1 motor for each wheel.
jorn
Posted: 09:58am 23 Jan 2024
It is fun to do all kinds of work with this little tractor.
I want to mount a sickle bar mower with double knife.
Revlac
Posted: 11:00am 23 Jan 2024
Nice work,
sickle bar mower should work well, they don't take much power to drive them.
Cheers Aaron
Off The Grid
jorn
Posted: 03:22pm 13 Feb 2024
What also comes in very handy is my cart with a low loading floor.
