Local Time 00:03 12 Nov 2026 Privacy Policy
Forum Index : Site News : Forum time zones
Posted: 12:45am 22 Nov 2017
I've recently moved the forum to a new server, and its based on a Brisbane Queensland Australia time zone of GMT +10 hours. The old server used GMT.
This means the dates and times on the forum posts may be wrong for you. The fix is easy, go to Settings ( top menu bar, under Memberlist ), then select Forum Preferences. Change the "Time offset from forum time" to suit your local time. It displays the local forum time, to make it easier to calculate the time offset.
