Forum Index : Other Stuff : What cheap 12v soldering iron to get?
karmacoma
Posted: 04:49pm 14 Mar 2017
I'm looking on eBay to buy a 12v soldering iron for occasional use on our 12v 100W remote area household PV system. The Scope and Weller ones are too expensive ($100+). The cheapies range from $7 to $30. There's all different wattages. Would 30W be adequate? Anything else about them that I should look for?
Among the Australian sellers, a "Toledo" 12v 30w seems to be sold by many, e.g. Toledo 12V 30W from SCA. Is that likely to be ok? Or am I likely to have trouble?
Basically the uses will be to tin twisted cable ends, solder repair various plugs and switches, that sort of thing.
-Ian-
greybeard
Posted: 07:42pm 14 Mar 2017
I had a low wattage 12v iron many years ago (30w from memory). Found it very slow to warm up and not very good at holding temperature. ie low duty cycle.
I now use a cheap 300w 240v inverter and my mains voltage weller iron for anywhere with 12v.
For occasional use it works well and if I happen to be around 240v then I still have a soldering iron I can use.
Posted: 08:54pm 14 Mar 2017
Thats a good idea greybeard. 300 watt inverters are so cheap, a modified square wave would be fine, and you could run any soldering iron you want.
I wouldn't use a soldering iron less than 50 watts. The higher wattage means you can heat up the joint and flow the solder quicker, so less heat damage.
karmacoma
Posted: 09:06pm 14 Mar 2017
Well I'm glad I asked. We haven't got an inverter, simply because everything we've got (not much - fans, a small tv, led lights, usb chargers and laptops) is direct 12v or dc-dc converted, and all our tools are hand tools.
So might not get an inverter this time around (though won't rule it out just yet). But now I know to look at the 60w soldering irons I saw on eBay, and avoid the 30w ones.
Thanks heaps
-Ian-
Posted: 09:33pm 14 Mar 2017
You could pick up an inverter for less than the soldering iron! A 300 modified square wave inverter goes for about $60. See http://www.radioparts.com.au/product/33779025/pin300usb?gclid=CJarrej-19ICFUlvvAodEbYDtg#.WMjtt_mGOHs
Be handy to have.
karmacoma
Posted: 12:16am 15 Mar 2017
Glenn, if you think that that Radio Parts one you linked to would be good, then that would give me confidence - it really is a low price - but I've got no background really to judge price/quality on inverters.
Is it an advantage to get a 300W inverter rather than a smaller one from the point of view of better efficiency even with smaller loads (like a 60W soldering iron), or is it just good to have 300W because you then can run appliances up to 300W?
The alternative - cheap 12V 60W soldering irons on ebay - cost $12 or so, and methinks they must be pretty dodgy. A brand-name 12V 60W+ soldering iron costs $100+. So the inverter route does make sense.
-Ian-
greybeard
Posted: 01:06am 15 Mar 2017
MY cheapo 300w inverter came from Jayacr. It's a modified square wave inverter. I usually chuck it in the camper for when I go away. SO far I've used it for the soldering Iron and for a small hand mixer when I was mixing a pavlova to cook in the camp oven. (Pav was great as well).
One of those handy things that has a lot of uses when you have to run a small 240v appliance from a 12v supply.
I've also used it for a small power drill.
I wouldn't run my camp from it but it's a handy purchase.
Boppa
Posted: 02:44am 18 Mar 2017
I would say either get an inverter and use a temp controlled iron or get a butane soldering iron- I have and use both for autoelectrical work, the 12v irons take `days' to get up to temp (well it seems like it) and I have never had one survive more than a couple of uses- the element seems to fail very quickly
Depending on what you are soldering, a 30w is almost useless for anything over 2 or 3mm- 60w up to 5mm but for bigger cables a 120w is the best, and can be used on anything smaller as well
But I still mostly just use my gas fired iron (its a portasol, but they are $$ because trade quality)- for occasional use- cheaper ones (jaycar has them) are fine
best thing with a gas iron is many you can unscrew the soldering iron tip and change bit sizes- or change to a gas flame and solder even battery terminals on starter motor cables
(also handy for starting campfires when you run out of matches lol)
