Local Time 00:13 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Crosley IcyBall
dwyer
Posted: 07:46am 02 Feb 2008
Hi everyone
Has anyone has own or work with Crosley IcyBall in Aussies
Crosley IcyBall
Crosley bought the rights to the Icyball refrigeration idea, and brought it to market. Powel Crosley had a gift for recognizing great ideas and gift for marketing. Crosley built thousands of Icyballs in at least two factories, one in the United States and one in Canada. Icyballs have been spotted throughout North America and as far away as Africa. The Canadian made Icyballs carry a tag indicating that they are Deforest Crosley Icyball, those made in the USA are labeled Crosley Icyball.
The Icyball is an intermittent heat absorption type of refrigerator. A water/ammonia mixture is used as the refrigerant . Water and ammonia combine easily. So, they combine in the hot ball at room temperature.
When the hot ball is heated, for about 90 minutes, the ammonia evaporates first because it has a lower boiling point than water. The other cylinder is in water to help condense the ammonia in the cold ball. When the balls are fully charged, the cold ball is placed in the insulated box, as the ammonia evaporates to recombine with the water in the hot ball it removes heat, cooling the inside of the refrigerator for 24+ hours. A hole in the cold ball was for a special ice cube
At the momest l can,t get a vidoes clip on due problem with my computer
Dwyer the bushman
Posted: 10:04am 05 Feb 2008
Wow, never heard of them. Just goes to show you learn something new every day.
AMUN-RA
Posted: 11:18am 05 Feb 2008
http://en.wikipedia.org/wiki/Icyball
Every day the sun shines
& gravity sucks= free energy.
dwyer
Posted: 12:39pm 05 Feb 2008
There photoes
dwyer the bushman
