Local Time 02:37 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Tilt table Gravity Assisted Pulse motor
govertical
Posted: 11:57pm 13 Jun 2016
https://youtu.be/4Oj5fGAKXaE
Hi, I found the above video showing manual operation. I am attempting to to automate the operation.
https://youtu.be/mVWJ5Dnr8-c
https://youtu.be/iJujIiis5lg
Posted: 01:53am 14 Jun 2016
Mate I wish you could understand the laws of thermodynamics that will explain why these machines will not work. You've put a great deal of work and clever design into your attempts over the years, but its wasted effort.
In that first video, the man pushing up and down on the contraption will be exerting more effort than was gained in lighting the light bulb. It would have been easier if he hand cranked the push bike wheel.
Gravity assist only works in one direction, down. As soon as you go back up, the energy gained is lost, plus a bit. That weight may be going around a axis, but its also going up and down. No gain.
govertical
Posted: 02:04am 14 Jun 2016
Hi, thanks for the info. I should be testing in a few days, I will post results. The only claim at this time is it not a overunity project. It is good to know you will keep things honest and on the up and up. No word games or smoke and mirrors on my part. Cheers
govertical
Posted: 04:43am 03 Jul 2016
https://youtu.be/bI8Rh0xDI4I
swing 5 configuration
https://youtu.be/jKIWcJiJs04
Combining the above configurations for better results. Using electromagnet to drive it past the dead spots. It will be a pulse motor driving a PMA. Output shaft will have a max RPM with no load. Under load, output will always be less than 50% of the power at the input similar to a wind turbine.
Posted: 12:42pm 03 Jul 2016
If you spent 10 minutes with a university science teacher, he would explain to you why this can never work, and you would save yourself a lot of time and effort.
The simple test is, put your device in a box. At one end is the output, electrical power in your case. At the other end in the input. This is where you supply the device with the power it needs to run, a little solar panel in your case. Now....
THE OUTPUT WILL ALWAYS BE LESS THAN THE INPUT.
There are a bunch of laws that say this, and if the laws were wrong, no machine in the planet would work. Ask the science teacher to explain it.
Therefore if you intend to power this "box" with a little solar panel, say 20 watts, then the output power MUST BE LESS THAN 20 watts. No amount of trickery inside the box will give you more power out than you put in. Gravity can not be used as a source of self replenishing energy, think of gravity as nothing more than a spring.
I dont meant to be rude, your efforts and workmanship are admirable and you seam like a nice person, but you are wasting you life.
govertical
Posted: 01:25pm 03 Jul 2016
https://youtu.be/aaF1_AyZe-c
pulse motor technology will be used to move a weight when the input rotor is horizontal. Your correct the output will always be less then the input power.
It will be just a motor driving a PMA. I will post test results when available.
This is not a OU project.
powerednut
Posted: 02:19am 04 Jul 2016
Go, I admire your craftsmanship, but....
I can't resist asking.
Why are you driving a permanent magnet alternator with a motor?
Why move the weight?
One gravity assist motor I've seen that works is water being pumped up to a tank. You trade a small amount of power over a very long period for a large amount of power over a short period. From an efficiency standpoint the power loss was horrendous. On the other hand the small amount of power wasn't doing anything anyway, and they had the big power on tap (heh) when needed.
govertical
Posted: 04:52am 04 Jul 2016
Hi, the main project is a stirling engine but it is summer and just to hot for a fire. The gravity assist pulse motor is a test fixture for a DC to DC step down circuit with a variable duty cycle that can be used with a PMA. It will give a visual result when the duty cycle is increased and decreased.
govertical
Posted: 07:26am 04 Jul 2016
https://youtu.be/S4O5voOCqAQ
I am also searching for a better solution.
govertical
Posted: 03:12am 05 Jul 2016
https://youtu.be/BPPi8cVoEmg
Idea from other projects on YouTube.
govertical
Posted: 01:43am 06 Jul 2016
One way bearing installed at the flywheel, now the flywheel can function like a wind turbine. So the Betz's limit will apply to the flywheel.
https://youtu.be/QPeIDnyDxvw
Posted: 02:04am 06 Jul 2016
How can the Betz limit be applied to a flywheel? The Betz limit dictates how much energy can be captured by a wind turbine, from the wind passing through it. Are you passing air through your flywheel?
govertical
Posted: 04:05am 06 Jul 2016
Hi, if you try to draw more power than 50% from the wind turbine what happens? I think it will stall. I view the motion of the flywheel the same way. I plan to pulse the output from the PMA at less than 50% to prevent system stall.
https://youtu.be/cWCytxxExws
Video from 2 yeas ago.
Are turbine blades a large flywheel?Edited by govertical 2016-07-07
Posted: 08:58pm 06 Jul 2016
Well if you want to use 50% of the available power, then say that. Dont compare apples to oranges, a flywheel is not a wind turbine, and therefore Betz does not apply. You may as well compare a gravity assisted motor to a diesel engine because they both have flywheels.
If you draw 50% of your power from your flywheel, it will also stall, unless you put more than 50% back in. If you draw 1% from your flywheel, it will stall, just takes longer.
govertical
Posted: 02:26am 07 Jul 2016
https://youtu.be/woVzF59FcsQ
govertical
Posted: 06:00am 08 Jul 2016
https://youtu.be/73C44sX-xLs
https://youtu.be/B3dLzZZ5jKQ
Combining the above ideas to complete the project, it should take a few weeks.
govertical
Posted: 03:53pm 17 Jul 2016
https://youtu.be/2u0krL4SW6Q
fillm
Posted: 04:08pm 18 Jul 2016
Wata Wonderful contraption and a credit to your skills and engineering ability. Still no meaningful power output but it could be a great exhibit piece for interactive power generationon on the mA scale.
Macgyver loaded a link to a water pumping wind sail that would suit this, as it waves to either side like a pendulum as and sits on a platform in a dam pumping water.
It would be amazing to see what you could produce if you really got serious about designing a HAWT but something tells me that its just not your cup of tea.
govertical
Posted: 06:01pm 18 Jul 2016
No wind, no power and I live in a low to no wind area. Gravity is always on.
http://www.engineering.com/ElectronicsDesign/ElectronicsDesignArticles/ArticleID/11200/Electricity-from-Human-Power.aspx
http://www.rapidtables.com/convert/electric/Joule_to_Watt.htm
math for the power calculations
I should be testing in a few weeks.
Posted: 07:23pm 18 Jul 2016
Gravity is NOT a ever lasting energy source. You can use it once to drive a mechanism. To reset, you MUST put in more energy that you took out.
Gravity is no better than a spring. You can wind it up, use the stored energy, wind it up, use the stored energy, etc. But you will ALWAYS get less out that you put in.
At some point to need to say "Maybe the guys on Other Power and TheBackShed were right, I cant break the laws of physics. This gravity assisted motor wont and will never work!", and then put your talents to building a better mouse trap or something. Its up to you to set that point. You've been at this for years now, when will it be enough time and effort wasted?
