Local Time 03:19 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Wanted
VK4AYQ
Posted: 12:30am 31 Aug 2014
Anyone got a spare LG stator winding they are not going to use as I started building a Turbine with one and it got damaged when I had a fire in my shed several years ago, to far gone to rewind.I have seen several stator's since but not as big as the one I have.
I have gone to the trouble of fitting neo magnets to the rotor so it is worth persisting with if I can get another stator.
All the best
Foolin Around
brucedownunder2
Posted: 10:42am 31 Aug 2014
Hi Bob ,
Thanks for the nice thoughts,re my "Hosspiddle" stay ..
Yes, I think I have a untouched one or the modified one in the picture posted in the next topic.
You are most welcome to either .
I would like to see the results of the Neo conversion ,as I intended to do this ,but got sidetracked .
My neo F&P was very successful,still have it but one word of warning to all, re F&P rotors.
These rotors are weak in the spline ,remember, they are only plastic ,and with the removal and fitting while experimenting they do wear considerably .. The LG can be retrofitted with a machined metal spline, as it's original spline is removable .
I do think LG's will be a better all round producer,but none has yet perservered with them ,same as the Sealy ,although Oztules(John) did a lot of work - Thanks John.
Bob ,how about you come on down one day and we'll chew the fat and you can select what you require ..
Bruce
Bushboy
VK4AYQ
Posted: 01:42pm 31 Aug 2014
Hi bruce
Thank you very much for that, I really appreciate it, I will bring the rotor to show you when I come, will be several weeks before I can make it as I too am getting over a botched medical intervention and am just getting going again, I did some testing on the LG and posted it several years ago i will look it up and repost it for general information, I think from memory it ws doing around 700 watts as set up in the lathe.
I will contact you on PM and make arrangements for visit next week.
All the best
Foolin Around
VK4AYQ
Posted: 01:58pm 31 Aug 2014
http://www.thebackshed.com/forum/forum_posts.asp?TID=3295
Hi Bruce et al
The link to the original experiment is as above,
All the best
Foolin Around
