Local Time 03:40 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : tankless electronic water pump
brucedownunder2
Posted: 10:57am 24 Oct 2013
here's one for the tank water residents..
I've got two systems- a pressure tank(bladder inside) type old water pump and a new electronic water pump.
Question is -- how do I adjust the pressure of the new type electronic water pump ?
The old type,,toilets fill slowly and allways cut off at the correct volume.
New type , toilets get a rush of water(pressure too high,maybe) , and so keep overflowing ..
on the new type electronic water pumps there is a small slotted nylon "thingo" like a flat headed hidden screw at the end of the pump bell housing . Is this anything to do with the adjustment?
Bruce.
Bushboy
domwild
Posted: 01:09pm 26 Oct 2013
If it is a float-based system then you can of course adjust the level of filling via the float lever adjustment, but then it will not fill fully with the older system. The float lever should still shut off quickly regardless of how much water volume/pressure is applied as it is a mechanical seal, so I do not understand your predicament.
Winston Churchill
Georgen
Posted: 07:07pm 28 Oct 2013
I think that seals are not suited for higher pressure and they let water through.
Possibly they got worn out or they were not designed for this pressure.
Interesting if you can reduce pressure on your pump?
Alternatively you can install permanent in-line pressure reduction device and adjust it to match pressure from old system.
George
brucedownunder2
Posted: 07:37pm 28 Oct 2013
Thanks Guys ,
I think there is a dip switch in the controller that can adjust the water delivery pressure,,I'll speak to the water pump man tomorrow..
nothing to do with the cistern --- it is governed by a float switch/cock..
but my guess is because the water pressure is gushing in so fast with this new high pressure electronic pump , then is sort of overflows before the float cock can come into play . the slow ,low pressure pump just gradually fills the cistern and the float cock can cope with that ...
all 3 of my cisterns do the same thing--ok with the old low pressure pump ..
thanks for thinking
bruce
Bushboy
Posted: 09:42pm 28 Oct 2013
Normally there is a tap on the wall just below the cistern, throttle the water back by half closing the tap.
Pete.
brucedownunder2
Posted: 09:58pm 28 Oct 2013
Hi Pete, never thought of that --bloody most logical thing to do --- gee, at 68, i'm getting ,forgetting , the most logical things that I've learn't over the years
Thanks crew
Bruce
Bushboy
Posted: 10:40pm 28 Oct 2013
Yeah, we often dont always see the logical, its a bit like not being able to see if the sprinkler is working because its raining.
Pete.
domwild
Posted: 12:37pm 01 Nov 2013
Bruce, old age is terrible, try to avoid it!
When a stunning blonde walked past our house the other day my pacemaker opened the garage door!
Winston Churchill
