Local Time 03:30 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : need serious help
brucedownunder2
Posted: 11:10am 30 Jul 2013
having a bad year----
I'm still logging on 4th jan. last .. No mattere, how many hundred times I go to 'settings" nothing changes -yes,yes, I've done the changes and saved the changes an hundred times ,honest.
Loading pics --I've been trying to reply to that dual stator posts ,maybe more than 20 times ,trying to up load some pic's of how I did mine ,,no luck , ...
I've probably posted a couple hundred pics on the back shed ,but for this past horrible year nothing I do seems to stay fixed - At least i'm booked into hospital soon for a new pacemaker ,,have had alll my tests ,,I've been feeling completly stuffed this year ,,,the ol heart is just not cutting like it used to ..
Could someone ,help me fix the time thingo ,,oh,, and the pic posting.
Bruce
Bushboy
muddy0409
Posted: 01:24pm 30 Jul 2013
Hi Bruce.
I found you really need a 5 year old to make these techo things to work properly.
Unfortunately, my kids are all much older than that, so no help at all...
Edited by muddy0409 2013-07-31
Don't poo poo conspiracy theories.
Remember that everything ever discovered started somewhere as a theory.
Posted: 05:21pm 30 Jul 2013
I just tried to post a test pic above and it workd as normal.
You need to use the image upload button above.
Then use the browse button to select you photo from your computer file.
Click OK and you should get a message to be patient while the file uploads to the server, click OK...... wait and ......wait......and wait.....
The server has been very slow for me of late to the point i crash out and give up on waiting for pages to load, so perhaps thats the problem for you too, even this post got hung up waiting for the image upload window to open.
Often upload problems can be caused by the size of the photo file being used, and with todays cameras the file can be massive in size and the forum might reject it or take forever to upload it, as there is a 1000kb file limit allowed for this forum, and most photos can be up into the mega bytes nowdays.
I usually open the photo in "Paint" and use "resize" and reduce the image to around 40%, then use "Save As" and save the photo to the same name and add "small" to the file name, this way i keep the large file and a smaller file of the same photo.
The small file is the one i use to upload to the forum.
I hope that helps you.
Pete.
Greenbelt
Posted: 05:02pm 05 Aug 2013
Hi Bruce, Could this be your problem?
Fix computer clock
Cheers------------Roe
