Local Time 03:19 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Attaching copper wire to tube
imsmooth
Posted: 03:12pm 23 Apr 2013
I want to solder copper wire to some stainless steel tubing to increase the surface area I'm working on a regenerative cooler any tips on the best way to ataxic copper wire to the stainless steel tubing would just plain soldering work
I'm trying to create feigns to increase the surface area
MOBI
Posted: 12:15am 24 Apr 2013
  Quote  I want to solder copper wire to some stainless steel tubing to
Is the copper wire insulated (varnish coated) or plain copper?
Both copper and stainless steel will take lead/tin solder quite happily provided you use adequate flux. Zinc chloride (killed spirit) will work well especially with a solder or tin paste.
David M.
Ron B
Posted: 11:15pm 26 Apr 2013
Would it be easier to make or obtain some stainless washers and fit them to the tube as fins? what is the tube diameter and length?
