Local Time 02:58 21 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Small Lister mounting
windlight
Posted: 11:21pm 01 Oct 2011
I am mounting a small Lister 3.5HP @1500 rpm onto a concrete block, I have seen stationary engines with a hardwood block between engine base and concrete block and some without.
I can only guess it provides a little dampening and or as is mostly the case the flywheel projects below the base and the hardwood block represents a spacer.
Any opinions on this point?
Allan of the jungle
Posted: 11:38pm 01 Oct 2011
I've heard if you mount a diesel, especially a single cylnder, on concrete, the vibration can travel a long way. If you house/shed is on/near the concrete pad, then the whole building becomes a sounding board.
Wood blocks would help, but rubber would be better. Got any old tires you can cut up? Or some old vehicle engine mounts.
Greenbelt
Posted: 01:36am 02 Oct 2011
windlight.
In addition to what Glen has suggested There is a problem with condensation causing rust or corrosion, the wood barrier is an insulator to prevent electrolysis with the earth. Edit; Best design is build a small Skid and and mount on rubber pads.
-----Cheers, RoeEdited by Greenbelt 2011-10-03
