Local Time 02:16 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : A Question of Curiosity
MacGyver
Posted: 04:15am 17 May 2011
Crew
I'm putting this here, because I don't where else to ask a silly question, being a senior member and all, but here it is anyway:
All of us here, myself included, have made alternators where we spin the magnets about a stationary stator. Has anyone tried it the other way?
The reason I'm asking is because I build all small stuff and making something small, but still robust enough to hold together when it revs up is somewhat of a challenge. I figured it would be less mass spinning about if I were to spin the stator. The only thing extra would be 4 slip rings (3 if you want ground to be the star connection). If you didn't want another three on the tower, you could rectify the current atop the genny and send it down the tower with one wire and a ground.
Also, for a small-ish build, it would be easier to create a huge magnetic field using ginormous magnets, then spin a hefty stator between them. That way, there'd be less chance of a magnet(s) shifting position while in use and turning the thing into a blender!
A mill turning a stator would need less inertial torque to get going too. It would still have to have the revs and torque at "cut-in" but in my opinion, it would seem to put less stress on things, assuming the coils were properly potted in the stator of course.
Sounds feasible to me; any takers?
. . . . . Mac
Copeville, Texas
RossW
Posted: 06:55am 17 May 2011
Ummmm... but isn't that just how an old car generator or brush-type DC motor works?
The difference is - you're doing away with the commutator - which I think would make your design less (rather than more) efficient, as you couldn't have multiple coils on the shaft unless you rectified on the rotor itself.
My gut feeling is that you'd end up with as much (or more) mass in copper windings and iron than you'd have had with magnets.
VK4AYQ
Posted: 09:24am 17 May 2011
Hi mack
The beauty of the axfx design is no iron in the stator to have eddy currents and decrease efficiency also the versatility of having a few combination of coils for different voltages.
To make a stator into a rotor as this design is made it would requite a lot of balancing of the then rotor which with our manufacture methods would be difficult and would require a lot of extra reinforcement in the structure to allow for the centrifugal forces.
The addition of the extra set of slip rings means extra losses and something else to go wrong.
It certainly could be made to work but as Ross said would it be a step backwards? I think that a design based on an outrunner model motor would be a good experiment, but would require a lamination press to make the stator.
All the best
Foolin Around
Posted: 01:59pm 17 May 2011
  MacGyver said   Crew
. . . . . Mac
Mac, I even went one step further, spun each in opposite directions to get a very low cut in . This requires counter rotating blades BTW.
It was was done with a F&P and a Lenz 2 VAWT. Balancing was no big problem with the F&P stator, I even mounted all the rectifiers on the stator disk so only 2 slip rings were required.
Did it work? Well, you might want to find out for yourself if the tinkering bug really gets hold of you .
Suffice to say this arrangement is no longer up on my windgen mast
MacGyver
Posted: 09:46pm 17 May 2011
Crew
Thanks for the input, guys. I kinda thought that's the way this would go and it's why I initially called it a 'silly question'. I have a very tiny (read that 4") ax-fx dual magnetic plate set-up that has been nothing but a pain in the arse. I have all but decided to turn it into an air core and let it light an LED just to have something spinning above my place; something to yack and cackle about. I may still do just that using a skein-wound, single-phase stator just for ease of assembly. Yeah, I know . . . it'll vibrate like hell.
Because all my stuff is so small (read that too small to be practical) I'm seriously thinking about going back to building windmills that compress air. That would at least give me a several-minute burst of energy if I were to run a tank of stored compressed air through an air engine coupled to an alternator.
I'm just finishing up my solar water heater rebuild and when it's done, I'll get back to building things that spin in the wind.
Thanks again.
. . . . . MacEdited by MacGyver 2011-05-20
Copeville, Texas
