Local Time 01:56 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : earthquake proven mill
shawn
Posted: 07:20am 04 Sep 2010
Hi guys mill servived 7.1 quake today!! power out everyware except my home and 130 km gust winds (met report) for next two days!! should be fun.
I am at the center of were the quake hit (not fun) but nobody hurt .
Bryan1
Posted: 07:49am 04 Sep 2010
G'day Shawn,
Glad you came out unscathed after that quake, some of the pic's on the web so show why NZ is called the Shaky Isles....
shawn
Posted: 10:30am 04 Sep 2010
thanks brian this is the first earthqake I have ever felt and the biggest ever around here anyway.
I blame australia just dosn't want to let go of its earths plates
our goverment has sold everything, so will probly only hert overseas owened insurance companys
On a diferent note i still am building a new gen but waiting for you and glen to do all the hard work turns of wire etc .
May have got a frend hooked as well these things are adictive.
Posted: 04:56pm 04 Sep 2010
Hi Shawn,
Good to hear you came threw the tremor ok, and the mill survived.
130 kph winds will test the mill out and think you will need more than the vacuum cleaner this time to pull a load.
Speaking of pulling a load, guess you could do a few loads of washing to clean your underpants after the quake.
I always thought New Zealand wasn't all cracked up to be what others made it, But it is now from what i seen on the news.
[quote]I blame Australia just doesn't want to let go of its earths plates [/quote]
Its the law of the jungle mate, the Superior will always survive.
Good luck in the coming days.
Pete.
shawn
Posted: 10:20am 05 Sep 2010
Hi there pete mill spiking to 45 amps at 26 volts but likes to sit around 20 - 27 amps
Have balanced prop much better sounding now!! and built state of the art dump
consisting of fence wire (high tensile) wraped around fluresent light tube LOL now when the dump switches on the amps go up a little sure there is a reason for this but this kiwi will never work it out
I think we are one meter closer to aus, wonder if flights get cheaper?
Did not have time to put underpants on (or anything else)so no washing needs doing.
Posted: 04:43pm 05 Sep 2010
What you got caught with your pants down.
The reason the amps go up on the dump load, is because the dump do not have to get to a cutin voltage like a battery, so it works from zero volts upwards where as the battery needs to have the mill generate above 24 volt before the current starts to flow into the battery.
Good you got a sturdy dump sorted, much better than the light globes.
Pete.
