Local Time 01:28 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : laptop fuse location
brucedownunder2
Posted: 09:34pm 10 Apr 2010
I have a compak preserio laptop ,fairly small old . I reckon the fuse is blown internally . do any of you know how to take the case apart to get to the internal fuse,please.
Bruce
Bushboy
vasi
Posted: 10:06pm 10 Apr 2010
youtube
youtube 2
Web
And so on...
Searching phrases on net: "Dismantling a Compaq Presario Laptop", "Disassemble a Compaq Presario Laptop"
Hope this can be helpful.
Vasi
Edit:
An old model?
Usually,the fuse must be close to the power jack... Edited by vasi 2010-04-12
Elvish name: Mablung Miriel
Beyound Arduino Lang
GreenD88
Posted: 02:15am 11 Apr 2010
Fuse? I've never seen a laptop with a fuse. More likely the computers either Fried or the power supply is fried. Check the power supply for voltage then make sure the power connector inside the laptop is not loose or broken.Edited by GreenD88 2010-04-12
Licensed Master Plumber / EPA 608 Universal License / 410a Safety Certified / Medical Gas Brazer/Installer
vasi
Posted: 02:42am 11 Apr 2010
  GreenD88 said   Fuse? I've never seen a laptop with a fuse. More likely the computers either Fried or the power supply is fried. Check the power supply for voltage then make sure the power connector inside the laptop is not loose or broken.
Of what I read so far, Compaq Presario have a fuse on board.
Posted: 04:32am 11 Apr 2010
My laptop owner has a short fuse.
vasi
Posted: 06:39am 11 Apr 2010
GreenD88
Posted: 02:12pm 11 Apr 2010
Well I guess they do I've never had a problem with one before so I didn't know they were there. Now fuse's don't usually blow for nothing so buy several of them, (DigiKey), maybe yours was just old and decided to blow. But if not you might go through a couple before finding why it blew.
brucedownunder2
Posted: 09:29pm 11 Apr 2010
Thanks crew, I got her apart fairly easy ,,will check that fuse ,haven't seen it yet,but I'm progressing ,sort of a between jobs thingo.
Thanks again
Bruce
Bushboy
