Local Time 00:47 12 Nov 2026 Privacy Policy
Forum Index : Other Stuff : a way to count rpm?
johnj
Posted: 07:47am 24 Sep 2009
Instead of messing with bicycle computers and stuff, I thought why not paint stripes on the hub of the mill/whatever device you have, to get an idea of rpm.
I had these stripes, (are they stroboscopic?), on my old record player.
You could have a set of stripes for cut-in, and what ever you wish to know.
Anyone tried this? howto do it?
cheers, J
davef
Posted: 09:36am 24 Sep 2009
The system you are talking about was to adjust the turntable speed to within a few percent of the correct speed.
Do a search on optical sensors like found in PC mice. Or slotted disc.
Good luck
MacGyver
Posted: 04:28am 10 Oct 2009
I'm working on a blade-pitch system that actually allows the windmill to speed up instead of slow down. When it's done, I intend to paint one blade white so it can be tracked with a video camera. If you're interested in a windmill's rpm, maybe this will work for you as well.
Copeville, Texas
